tailwheel shimmy
Posted: Tue Aug 16, 2011 11:30 am
by Jeffrey Whitesell
'Hello Fairchild enthusiasts
I'm new to the group---Just started teaching in a PT-19. Got a little tailwheel shimmy that shows up intermittently on the landing rollout....Any suggestions?
Jeff Whitesell
topfun@fivetogether.com'
Re: tailwheel shimmy
Posted: Tue Aug 16, 2011 2:43 pm
by Jim
'Hello Jeff
If you search the previous chats on this site your gonna find quite a few previous chats regarding this subject. It's been an issue/topic of conversation for the PT and F24's for years.
There is a lot of wisdom and BS in the conversations, but what works for one may not work for another. For my own I found I needed new keys in my strut and re-shimed the trailing link collar. No more issues.
Good luck
Jim Higham
F24
81207
> Jeff Whitesell
Posted: Tue Aug 16, 2011 3:02 pm
by Curt Kinchen
'I concur. Note that many PTs have fully splined shafts vs the 2 keys
mentioned by Jim found in a lot of F-24s.
On Tue, Aug 16, 2011 at 1:43 PM, Jim wrote:
> Hello Jeff
> Good luck
> Jim Higham
> F24
> 81207
> suggestions?
> > Jeff Whitesell
ptcurt@gmail.com
Posted: Tue Aug 16, 2011 3:26 pm
by Cy Galley
'Land slower and have the tailwheel centered when lowering. Check to see if
the tailwheel and the rudder are pointing in the same direction.
Cy Galley; Editor - BC-Contact!
Supporting Bellancas every day
www.bellanca-championclub.com
On Behalf Of Jeffrey Whitesell
Sent: Tuesday, August 16, 2011 12:31 PM
Subject: [fairchildclub] tailwheel shimmy
suggestions?
Jeff Whitesell
Posted: Thu Aug 18, 2011 5:59 am
by Airy Millet
'First, check Tyre wear and pressure....
Then rely to old post of this group dealing with shimmy and tailwheel arrangement end play!
Airy
ex-F-AZCI F24R mechanics.
Date: Tue, 16 Aug 2011 10:30:35 -0700
Jeff Whitesell
