'Mike
I am assuming you have a Ranger engine, if this is the case sorry but there is
no prop seal. It uses a slinger designed into the bearing retainer to keep the
oil within the engine nose case, if you blowing oil past thr bearing retainer
you may have bigger problems. There a few Ranger experts who may have seen this
before like the Denests, but my guess would be the crank case has had a build up
of pressure. Make sure your breather is clear of blockage, if it is then you may
want to perform a compression check for piston blow by.
Jim Higham
F24R46-108
fairchildclub@yahoogroups.com
Sent: Sun, July 3, 2011 8:06:02 AM
Subject: [fairchildclub] Blown Prop Seal
Phooey. This happened on the way to a fly-in yesterday and kinda ruined my day
plus the appearance of the front of the airplane.
Can someone in the group tell me when I can obtain a new seal and how difficult
a job it is to replace?
Ranger Mike
