F24 Fuel valve shaft seals?
Posted: Sun Jun 05, 2011 10:57 am
				'Folks, Am I correct in thinking that there are seals that fit around the shafts of the fuel shut off valves?
I have one retaining nut with what looks like the remains of a seal held in by a brass washer which I do not want to force out yet, and the other has nothing, but there is an unthreaded area at the base of the nut below the thread that looks like it should have a seal or something.
If seals should be there what are people using for both the seal and retaining washers? or are you all relying on a well seated valve body to prevent any leaks!
Any guidance will be very much appreciated.
Frank
UC61K G-BCBL'
Frank
UC61K G-BCBL'
