Leaky Fuel Tank
Posted: Mon May 30, 2011 2:54 pm
				'I've been pursuing a fuel leak in my 24G wing for some time. I've tried sealant of various makes applied to the outside of the tank in the areas where it is obvious fuel is coming through the tank. The area in question is in and around the pressed-out sump on the bottom of the tank, where the inboard fuel pick-off is located. I've noted the same issue on other, un-mounted tanks. It seems a combination of time and perhaps moisture collection in that area contributes to the erosion of the aluminum in the thinned-out area formed when the aluminum was pressed to make the sump.
I can't be the first to have encountered this problem, and I'm about ready to bite the bullet and cut the fabric to get the tank out of the wing, and send it out for repair. Trouble is, since the area that should be replaced is the sump and perhaps a few inches surrounding, that pressed-out area will have be made and welded in, a bit more complex than just welding in a flat piece.
I'm wondering if anyone has had the same problem, and if I could get a recommendation to a shop that could tackle this?
Thanks in advance.
Bill McClure
Cape Cod, Mass.'
Thanks in advance.
Bill McClure
Cape Cod, Mass.'
