F24 Parts and Accessories
Posted: Tue Apr 19, 2011 12:14 pm
'Hello all!
I am working on my 1939 Fairchild 24R, and have run into three issues that I cannot seem to resolve. Wondering if someone could help??!
1) Fuel Lines. The original fuel lines are steel, and have been spliced MULTIPLE times - two splices per line, just to the fuselage. I would like to replace the old lines with new rubber; this would eliminate many sets of adapters, and be easier to work with. Does anyone know, can I run new soft fuel lines in lieu of the old hard lines?
2) Fuel Sending Units. My Fairchild has the 30-gallon wing fuel tanks, with the sending units mounted on the bottom. The sending units are shot and i would like to replace them. The units are marked with "TRAVEL ACCESSORIES 240 OHM, AUG 1977". I noticed from an earlier post that Stewart Warner p/n F385-C seems to be compatible; anyone have any further information on these?
3) Grimes Landing Light. One of the landing lights does not work; the bulb lights up, but the motor does not function at all. I cannot even turn the large gear by hand. Does anyone know of a place that works on these? OR, are they easy enough to service?
THANK YOU for your help;'
