Fuel Tank Cover
Posted: Mon Apr 18, 2011 8:05 am
'I am chasing leaks in right fuel tank, have opened up more inspection areas and can see the points in question. Seems to be the usual pitting from the inside creating "osmosis" right through. I have looked at some F-24 tanks on a project a/c, and see the same situation in the same areas. I am trying some ProSeal on the outside, hopefully it will work.
However, if I have to remove the tank I want to see what the concensus is on covering the tanks over completely with fabric, or leave open with the straps and tape around the edges? The project was the latter, mine is covered which makes the removal a bigger deal, obviously.
Any help on this?'
Any help on this?'
