--- In
fairchildclub@yahoogroups.com, Jim wrote:
> The website will not have what you are looking for. What you need is examples of 337 Field Approvals from previously modified aircraft to see how they accomplished their installation, you also reference this list of previously approved installations as part of your approved data in your Field Approval. These 337s will show exactly how install the brakes, which is simple, your IA can assist you. The only thing this chat room will show is the conversations regarding peoples installations. I do however recommend the Fairchild Club disc, as well as asking this chat group for registration numbers and copies of their 337s of previously approved aircraft. My registration number is N81207 and is F24R46-108, I also did a friends and his is N81363, F24r46-263. Although these are 24s and not PTs, the installations are the same and you can use the Instructions for Continued Airworthiness to help make yours. I would be glad to send you copies of mine but the Yahoo chat site won't allow attachments on emails, so if you email me at higham_jim@... I will forward it to you.
> Jim
> (319) 533-7890
> On Apr 7, 2011, at 12:52 AM, "Fritz" wrote:
> > Jim,
> > I don't have the CD from the Club. How can I identify which reference to
> > search to get it from the website??
> > Fritz
> > -----Original Message-----
> > From:
> > On Behalf Of Jim
> > Sent: Wednesday, April 06, 2011 9:11 PM
> > To:
> > Subject: Re: [fairchildclub] Cleveland wheels and brakes for fairchilds.
> > Have you got the data disc from the Fairchild Club? It's got a FAA Data
> > section with a good 8110-3 for a F24 and Field Approval 337 for the basis
> > of approval to convert yours.
> > Jim Higham
> > Aviation Turbines International
> > Engine Sales
> > (319) 533-7890
> > On Apr 6, 2011, at 10:54 PM, "Fritz" wrote:
> > > Well folks, I for one would like to get complete info on what is needed to
> > > convert my PT-19 to the 310 system.
> > > Thanks,
> > > Fritz Mehrer
> > > avdflyr@...
> > > Cell: 1-760-672-8126
> > > From:
> > > On Behalf Of Jim Higham
> > > Sent: Wednesday, April 06, 2011 8:40 PM
> > > To:
> > > Although it sounds logical that three pucks allow more braking action with
> > > less
> > > control than two pucks, but using the original master cylinder with
> > > Cleveland
> > > wheel cylinders having three actuating pistons (pucks) increase the
> > > amount of travel the master cylinder piston moves to displace enough fluid
> > > to
> > > actuate the braking action. By decreasing the wheel cylinder number of
> > pucks
> > > by
> > > a third also decreases master cylinder piston movement by a third and
> > > braking
> > > action begins a third quicker. My preference is the more pedal travel the
> > > more
> > > control you have as long as you don't run out of travel. These Cleveland
> > > wheel
> > > cylinders were designed to be actuated by a .625" diameter bore master
> > > cylinder,
> > > the Fairchild original master cylinder is 1.25" diameter bore displacing
> > > almost
> > > twice as much fluid as the Cleveland's need. I found when I installed the
> > > Cleveland master cylinder it increased the brake pedal travel and as far
> > as
> > > I'm
> > > concerned gave me better control and feel and it's almost impossible to
> > > accidentally actuate them.
> > > ________________________________
> > > From: Michael kelly
> > > To:
> > > Sent: Wed, April 6, 2011 9:57:01 PM
> > > Subject: [fairchildclub] Cleveland wheels and brakes for fairchilds.
> > > I was looking at the last Fairchild Flyer that John Berendt put out(2008
> > VOL
> > > 20
> > > #2. He had some information about the Cleveland conversion. The 310 Kit
> > has
> > > the
> > > 3 puck system. Some think the 3 puck is too much braking. I haven't heard
> > of
> > > any
> > > problems with the 3 puck system but I guess if you got a little heavy on
> > > braking, you could over do the braking and maybe nose the plane up. His
> > > article
> > > has a 2 puck system by Cleveland Part No. 20-278. The wheel size is still
> > a
> > > 650-10. I have a copy of a 337 for the Cleveland convertion on a PT in the
> > > Club
> > > files. Greg Ward did it years ago on the PT-23 they have in the Kalamzoo
> > > Aviation History Museum. There are a couple other PT's that have the
> > > Cleveland
> > > convertion on them that I know of. If anyone would like the owners names,
> > > let me
> > > know!
> > > Keep 'em Flying!
> > > Mike Kelly
> > > Fairchild Club
> > > [Non-text portions of this message have been removed]
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
