--- On Mon, 3/14/11, DAVID STROUD wrote:
Subject: Re: [fairchildclub] Should I part it out?
fairchildclub@yahoogroups.com
Date: Monday, March 14, 2011, 5:11 PM
Just for reference, probably not needed for this trip but you can get 24 fuselage into a standard tractor
trailer van with the horizontal stab off. The gear shocks get removed, the aircraft lifted up and longer
temporary "shocks" get installed to pinch the wheels inboard. We used angle iron pieces in place of
the gear as temporary shocks and the plane was transported most of the way across Canada no sweat.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Sent: Monday, March 14, 2011 4:58 PM
Tom,
Last year we moved a PT-19 by truck (proper permits, no escort required). It was daylight hours only. I think 30 minutes after sunrise to 30 minutes before sunset and the route has to be approved by DOT. We traveled through three states. Permitting in two of them took a couple of hours, and the third took 2 1/2 days.
Check the outside dimensions on your horizontal stabilizers. It only took a few extra minutes to remove them, so we did. I don't know if the gear width on the F24 is the same as the PT, we did have to fab a cradle out of 4x4s for the gear to ride on. If you want, you can send me a PM at
jsharpsmail@yahoo.com and I'll be as helpful as I can.
Joel
Sent from my iPad
On Mar 14, 2011, at 9:58 AM, "Craig" wrote:
> Tom: I did a quick check, and for WA, a permit for overwidth loads is only 10$ plus 7 cents a mile. Take the wings off and leave the tail on and do the permit. You might have to have an escort and run between certain hours, but it would cut down on the work to move it.
> Craig C.
Checked by AVG -
www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3504 - Release Date: 03/13/11 07:34:00
