Re: Warner Engine degree wheel
				Tom_Downey
'Anyone know where I can beg, rent, borrow or buy one?'
				Tom_Downey
'One can use a precision electronic level instead.
Cy Galley - Chair, AirVenture Emergency Aircraft Repair
A service project of EAA Chapter 75 since 1963
www.eaa75.com
On Behalf Of Tom_Downey
Sent: Wednesday, March 02, 2011 10:15 PM
Subject: [fairchildclub] Warner Engine degree wheel
www.eaa75.com
				Patricia Banks
'Tom,
I machined a custom degree wheel for my Jake. Its about 14" in diameter and mounts on the front of the power case. I then made a split clamp with a pointer that mounts on the crankshaft between the case and back of the prop. I set TDC on #1 with a time-rite and then adjust the pointer.
It was a lot of work but man did it make setting the Mag/Distubtor timing and valve clearances a breeze. I'm sure you could make something similar for the Warner. If I get a chance I'll post some pics of it in my group album.
Matt
F25-N4263S
Matt
F25-N4263S
Date: Wednesday, March 2, 2011, 11:14 PM
