Page 1 of 2
Master Rod Bearings
Posted: Fri Dec 31, 2010 1:34 pm
by Tom_Downey
'I have found a method of renewing the master rod Babbitt in any size up to .008" under. anyone interested?'
Master Rod Bearings
by Tom_Downey
Re: Master Rod Bearings
Posted: Fri Dec 31, 2010 7:22 pm
by John Duncan
'Hello Tom,
I am interested in learning about your new procedure.
Regards, JD
Sent: Friday, December 31, 2010 12:34 PM
Subject: [fairchildclub] Master Rod Bearings
Posted: Fri Dec 31, 2010 7:40 pm
by OldOOwl@aol.com
'me too!
In a message dated 12/31/2010 6:22:25 P.M. Mountain Standard Time,
johnaduncan@msn.com writes:
Hello Tom,
Regards, JD
Posted: Fri Dec 31, 2010 8:24 pm
by Kevin Trumpore
'Tom, Please pass on the info, hopefully it will be easier / cleaner than the method we have been using. I get called upon to do a half dozen or so babbitt bearings a year. Never fun, never profitable, but it does keep an antique running.
Kevin
Date: Friday, December 31, 2010, 2:34 PM
Posted: Fri Dec 31, 2010 8:30 pm
by Tom_Downey
'I trying to Get a feeling for the market, I have found a company that will regrind a crank and rebabbitt the old bearing shell, and fit the two parts at the proper clearance.
the number will reflect the price.
> Kevin
Posted: Fri Dec 31, 2010 9:05 pm
by Fritz
'Which engines are affected with Babbitt bearings??
On Behalf Of Tom_Downey
Sent: Friday, December 31, 2010 6:30 PM
Subject: [fairchildclub] Re: Master Rod Bearings
antique running.
> Kevin
Yahoo! Groups Links'
Posted: Sat Jan 01, 2011 3:11 am
by Tom_Downey
'I would like to collect a few old insert bearings for the warner and see what pricing on the lot will be. then place these renewed bearing on the shelf at Harlon Dickersons for any one who needs them.
by Tom_Downey
Posted: Sat Jan 01, 2011 9:20 am
by Gene Haines
'Are these bearings for the Warner? At first I thought the discussion was about Ranger engines.
Sent: Fri, Dec 31, 2010 9:24 pm
Subject: Re: [fairchildclub] Master Rod Bearings
Kevin
