'On 1/12/2010 7:50 AM, hotfoot49 wrote:
> I'm not an expert on the subject but over the years I have been told that a straight pipe might cause the exhaust valves to warp or burn due to lack of some back pressure. I knew a guy who had straight stacks on a Ranger but they had a little curve to them at the end. That's my 2 cents for what it's worth.
> Mike Kelly
> Fairchild Club
Hi All,
I'm not Fairchild owner & just lurk here, but thought I'd add my 2bits
on this.
A few years back my Dad had an engine failure in an Auster. This
aircraft has an inverted 4cyl Gypsy. The cause of the engine failure was
the exhaust valve head separating from the valve stem.
One of the observations made during the subsequent major overhaul, by
the Gypsy guru here in Aus was that the short straight stacks were not
good for the exhaust valves due to lack of backpressure. Whether that
was a contributor to the failure I don't know.
I think there is also something about replacing exhaust valves on the
Gypsy every 400 hours, and the failure occurred on No.2 Cyl which is
also the hottest in that engine. We don't know how many hours that valve
had been in service, but we suspected it might have been more than 400.
The aircraft is still flying with the single exhaust per cylinder as are
a number of other Auster's in Aus.
Don H
Sydney, Aus'
