				Spark Plugs
				Posted: Thu Aug 26, 2010 9:24 pm
				by basinaviation
				'Anyone know of a source to purchase BG 417S spark plugs?  It seems the REM 40's are readily available but I'd like the shorter/smaller plugs for the left side for clearance behind the carb. My ranger is -C5 engine.
 The previous owner left me som BG4B2s plugs. Are these interchangeable?
 Dave'
				Re: Spark Plugs
				Posted: Thu Aug 26, 2010 10:32 pm
				by Mike Danielle
				'Just curious..is your harness shielded?  Are the BG plugs shielded?
 Ranger Mike
 Sent: Thursday, August 26, 2010 8:24 PM
 Subject: [fairchildclub] Spark Plugs
 > Thanks,
 > Dave
				Re: Spark Plugs
				Posted: Fri Aug 27, 2010 5:26 am
				by David Stroud
				'This fella might. He's helped me before......
 http://www.plugguy.com/
 David Stroud     Ottawa, Canada
 Christavia C-FDWS
 Fairchild 51 replica
 under  construction C-FYXV
fairchildclub@yahoogroups.com
   Sent: Thursday, August 26, 2010 11:24 PM
   Dave
   Checked by AVG -
www.avg.com
   Version: 8.5.441 / Virus Database: 271.1.1/3093 - Release Date: 08/25/10 06:34:00
				Re: Spark Plugs
				Posted: Fri Aug 27, 2010 8:12 am
				by basinaviation
				'The harness is shielded as are the plugs.
  --- In
 > Ranger Mike
 > From: "basinaviation"
 > > Thanks,
 > > Dave
 > > Yahoo! Groups Links
				Re: Spark Plugs
				Posted: Fri Aug 27, 2010 10:02 pm
				by ccmueller001
				'The REM37BY plug is 3/8" shorter than the REM40E plug. It has exposed electrodes. Not sure if it has fed blessings for the Ranger though it does fit nicely behind the carb making access a lot easier.
 Charles
 --- In
 > Thanks,
 > Dave
				Re: Spark Plugs
				Posted: Fri Aug 27, 2010 10:12 pm
				by basinaviation
				'Thanks Charles. Mr Joe Denest came through for me and found a few BG 417s plugs for me.  Funny thing is while searching around on the internet, I missed an eBay auction for 15 of them by 2 mins.  They sold for only $13.50.
  --- In
 > Charles
 > --- In
 > > Thanks,
 > > Dave
				Re: Spark Plugs
				Posted: Mon Aug 30, 2010 1:44 pm
				by Tom
				'--- In
 > Thanks,
 > Dave
Dave,
 My BG manuals call for 417S or 4B2-S for all model Ranger engines.  I'm running the BG4B2-S now and have had  no real carbon fouling  or lead deposits. I'm not running any  additives in the fuel or oil to prevent  lead deposits. As  long  as they keep coming out reasonably clean , I don't plan on it. I bought a can of  4B2-S from Fresno Air parts .They were Manufactured  and sealed in a vacuum sealed can during the war years. They were like new. There's 30 in a can, I don't remember the price being outrageous. The 4B2-S type also has a little shorter neck (the shield tube on top the plug) which helps with the plug behind the Carb. Hope this helps,
 Hanford,Ca'
				Re: Spark Plugs
				Posted: Fri Sep 03, 2010 9:09 am
				by basinaviation
				'Thanks Tom.  Where can I get a copy off that BG manual?  I've noticed on other engines the two plugs were interchangeable but the FAA certificate for ranger engine only lists the champion plugs and BG 417s.  Anyway to convince the Faa to make an update?  Might take another 40 yrs but its a start....
  --- In
fairchildclub@yahoogroups.com, "Tom"  wrote:
 > --- In
 > > Thanks,
 > > Dave
 > Dave,
 > Tom
 > Hanford,Ca
				Spark Plugs
				Posted: Mon Oct 28, 2013 11:51 am
				by james chybicki
				'Hi All!can I get some input on Spark Plugs for a 200 HP with a Fresh "0" hour Overhaul?I pulled the Champion REM40E off. I am flying in the Chicago area, so we will have HOT and COLD days.let me know what your running?thanksJIM CHYBICKIMidwest Aeronautique LLC1943 UC-61K  USAAF# 43-14964 / RAF # HB690
				Re: Spark Plugs
				Posted: Mon Oct 28, 2013 12:20 pm
				by james chybicki
				'Hi AllThis is for the 200HP RANGER engine
                           #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173 --   #ygrps-yiv-1339402917yiv3274914173ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp hr { border:1px solid #d8d8d8;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp #ygrps-yiv-1339402917yiv3274914173hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp #ygrps-yiv-1339402917yiv3274914173ads { margin-bottom:10px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp .ygrps-yiv-1339402917yiv3274914173ad { padding:0 0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp .ygrps-yiv-1339402917yiv3274914173ad p { margin:0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp .ygrps-yiv-1339402917yiv3274914173ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ygrp-lc { font-family:Arial;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ygrp-lc #ygrps-yiv-1339402917yiv3274914173hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ygrp-lc .ygrps-yiv-1339402917yiv3274914173ad { margin-bottom:10px;padding:0 0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173actions { font-family:Verdana;font-size:11px;padding:10px 0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span { font-weight:700;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span:first-child { text-transform:uppercase;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span a { color:#5085b6;text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span span { color:#ff7900;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span .ygrps-yiv-1339402917yiv3274914173underline { text-decoration:underline;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach div a { text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach img { border:none;padding-right:5px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach label { display:block;margin-bottom:5px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach label a { text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 blockquote { margin:0 0 0 4px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173bold { font-family:Arial;font-size:13px;font-weight:700;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173bold a { text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 dd.ygrps-yiv-1339402917yiv3274914173last p a { font-family:Verdana;font-weight:700;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 dd.ygrps-yiv-1339402917yiv3274914173last p span { margin-right:10px;font-family:Verdana;font-weight:700;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 dd.ygrps-yiv-1339402917yiv3274914173last p span.ygrps-yiv-1339402917yiv3274914173yshortcuts { margin-right:0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173attach-table div div a { text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173attach-table { width:400px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a:active, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a:hover, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a:visited { text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a:active, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a:hover, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a:visited { text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div#ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg #ygrps-yiv-1339402917yiv3274914173ygrp-msg p a span.ygrps-yiv-1339402917yiv3274914173yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173green { color:#628c2a;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173MsoNormal { margin:0 0 0 0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 o { font-size:0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173photos div { float:left;width:72px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173reco-category { font-size:77%;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173reco-desc { font-size:77%;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173replbq { margin:4px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg table { font-size:inherit;font:100%;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg select, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 input, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 textarea { font:99% Arial, Helvetica, clean, sans-serif;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg pre, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 code { font:115% monospace;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg * { line-height:1.22em;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg #ygrps-yiv-1339402917yiv3274914173logo { padding-bottom:10px;}   #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-msg p a { font-family:Verdana;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-msg p#ygrps-yiv-1339402917yiv3274914173attach-count span { color:#1E66AE;font-weight:700;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-reco #ygrps-yiv-1339402917yiv3274914173reco-head { color:#ff7900;font-weight:700;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-reco { margin-bottom:20px;padding:0px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ov li a { font-size:130%;text-decoration:none;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ov li { font-size:77%;list-style-type:square;padding:6px 0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ov ul { margin:0;padding:0 0 0 8px;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-text { font-family:Georgia;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-text p { margin:0 0 1em 0;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-text tt { font-size:120%;}  #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1339402917
