WARNER AR MAZE
Posted: Fri Aug 13, 2010 3:59 pm
by james chybicki
Hi Everyone
Does anyone with a Warner powered F-24 use the Air Maze  attached in the pictures?  If you can't open the attchment and you have the UC-61 Part Catalog AN01-115CA-4 look at page 62B Figure 58  I have a couple of these in N.O.S. condition minus the Filter. I also have a couple of the inlet tubes in Firgure 57 item 11  and Rubber connecting tubes items 24 & 10. If you can use them, please let me know.
Jim Chybicki
UC-61K 43-14964/HB-690
Re: WARNER AR MAZE
Posted: Mon Aug 30, 2010 4:14 pm
by wackett129
'G'day Jim,
Yes I would be very interested in obtaining the air maze housings from you as I do not have any on my aircraft. Inlet air on Argus Is was unfiltered which is not a good idea paticularly in a dusty climate such as we often get here. Please see the note I sent to Peter Chamberlain regarding contact details and if this is not suitable for you I can give you a number of a family friend in Sunderland who would pass on my email details to you.
John Gallagher
--- In fairchildclub@yahoogroups.com, james chybicki wrote:
> Hi Everyone
> Jim Chybicki
Re: WARNER AR MAZE
Posted: Mon Aug 30, 2010 6:01 pm
by Bob
'John Gallagher,
Yahoo provides the security feature of "not showing eMail addresses". This is a desired feature, since having your eMail address exposed on the web, increases the likely-hood of getting lots of unsolicited eMail.
YOU may show YOUR eMail address by merely writing it without using the @ sign and the "." in the address. You could instead use: *AT* and *DOT* For example, MY eMail address is RangerRobertMN *AT* Yahoo *DOT* com.
Good Luck.
Webster, MN USA
--- In fairchildclub@yahoogroups.com, "wackett129" wrote:
> G'day Jim,
> John Gallagher
> > Hi Everyone
> > Jim Chybicki
Re: WARNER AR MAZE
Posted: Thu Sep 02, 2010 8:19 am
by james chybicki
'Hello John
 I have never sold one before, but a couple 24W drivers figure these are worth a few hundred dollars ($250.00 -300.00 US Dollars.)  I would be more then willing to trade this even for a UC-61 Long Pitot Tube , Kollsman Type 765 that extends out of the left wing, about 1 foot from tip. It has a dog leg bend in it.
I also have a set of  throttle and mixture rod assemblies for the UC-61A that are also NOS from a large purchase I made a few years ago of Fairchild /UC61A/K parts
I can send you pictures of the AirMaze, but not through the web site.
I tried your direct yahoo mail given below, but it won't go through
Thanks/Cheers
--- On Mon, 8/30/10, wackett129 wrote:
Subject: [fairchildclub] Re: WARNER AR MAZE
Date: Monday, August 30, 2010, 5:14 PM
G'day Jim,
John Gallagher
> Hi Everyone
> Jim Chybicki
Re: WARNER AR MAZE
Posted: Thu Sep 02, 2010 9:38 pm
by wackett129
'G'day Jim,
Have been corresponding with Peter Chamberlain using the method suggested by Bob Waldron (thanks Bob)so try contacting me using antair at optusnet dot com dot au I will be at my hangar in the next few days and see what I can come up with.
Regards
John
> Hello John
> Thanks/Cheers
> Jim
> From: wackett129
> G'day Jim,
> John Gallagher
> > Hi Everyone
> > Does anyone with a Warner powered F-24 use the Air Maze�  attached in the pictures?�  If you can't open the attchment� and you have the UC-61 Part Catalog AN01-115CA-4 look at page 62B Figure 58�  I have a couple of these in N.O.S. condition minus the Filter. I also have a couple of the inlet tubes in Firgure 57 item 11 � and Rubber connecting tubes items 24 & 10. If you can use them, please let me know.�
> > Jim Chybicki
