Re: Master drawing index for the NASM/Smithsonian collection of draw
Posted: Wed Jun 02, 2010 8:40 am
by wclayman
'Hi Marc,
That is the baseline for the "Fairchild" drawings. There is another index, a
master index within the NASM where all their drawings are listed with
hyperlinks to all manufacturers drawings in inventory. The NASM and
Smithsoniam have many more drawings in inventory than are shown on the
accessable pages found on their re-worked foreground online pages/screens.
It is this master index url which I seek to find again. I had it...but the
url changed rendering my link(s) useless...therefore I seek the new address.
I appreciate and understand this discussion forum's Fairchild focus; I
belong to others as well...Weaver aka WACO for example.
Ed
To: "Fairchild Yahoo site post"
Sent: Wednesday, June 02, 2010 8:23 AM
Subject: RE: [fairchildclub] Re: drawings from NASM
> Try: nasm.si.edu/research/arch/collections/techdraw/fairchild24.cfm That
> should do it. Marc
> From: wmclayman@comcast.net
> Date: Wed, 2 Jun 2010 05:46:12 -0500
> Subject: Re: [fairchildclub] Re: drawings from NASM
> Hugh,
> Yes, they are/were online. I will post the url when I once again have
> found it.
> Thanks,
> Ed
> From: Hugh Loewenhardt
> Sent: Tuesday, June 01, 2010 9:26 PM
> Hello wclayman, For my project, I use hard copies of the drawing indices
> obtained from NASM as explained in my reply to Jp.Lorie. If the indices
> for the various model F-24's are available on the Internet that is(would)
> be a great thing but at this point I am unaware of it. I will do some
> research to find out. Regards, Hugh
> --- On Tue, 6/1/10, wclayman wrote:
>> From: wclayman
> > Date: Tuesday, June 1, 2010, 4:35 PM
> > Hugh,
> > Your post is timely. The NASM indexes are being turned
> > topsy turby over the next two months. I lost the drawing
> > index url. Please share the "current" url for the
> > index. I spent three hours chasing the rabbit hole on
> > Friday. I found new resources, however I came up empty on
> > the url for the drawing indexes. There are many new avenues
> > in the NASM and Smithsonian web sites and data bases.
> > Thanks in advance for your contributions to this list.
> > Ed
> > From: Jp Lorie
> > Sent: Tuesday, June 01, 2010 11:16 AM
> > Subject: [fairchildclub] Re: drawings from NASM
> > Hi Hugh,
> > Can you tell us what NASM is and how to get to it.
> > Thanks,
> > Jp.Lorie
> > Florida
> > ________________________________
> > Sent: Fri, May 28, 2010 4:35:13 PM
> > Subject: Re: [fairchildclub] Motor Mounts
> > You may or may not find drawing 48107 in Jamies's CD as
> > it contains certification drawings only(not sure which
> > model) and is not inclusive of all drawings utilized in the
> > manufacturing process. The construction drawing indices for
> > each model(available from NASM) lists all the drawings used
> > to construct the various models. I just checked the drawing
> > index for the G model and drawing 48107 is listed as
> > applicable.
> > --- On Fri, 5/28/10, burnmcc@aol.com
> > wrote:
> > > From: burnmcc@aol.com
> > > Date: Friday, May 28, 2010, 1:35 PM
> > > OK, Many thanks. I have the Fairchild CD from Jamie,
> > a
> > > little hard to navigate (at least for me) but I will
> > see if
> > > I can find it with that info.
> > > Thanks again.
> > > Bill McC
> > > -----Original Message-----
> > > Sent: Thu, May 27, 2010 8:58 pm
> > > Bill, The original engine installation washer for
> > the
> > > Warner 145 on Fairchild 24's with integral
> > engine mounts
> > > is: a 1.250"x1.250"x0.1875"thick
> > washer with
> > > an 11/32" center hole. The washer is
> > manufactured from
> > > brake lining material. Dimensions and material are
> > as
> > > specified by Fairchild drawing number 48107.
> > Drawing
> > > applicability is: C8C,C8E,24G,24J, and 24W9. The
> > drawing is
> > > available from NASM or I can send you copy. Your
> > choice.
> > > Hugh Loewenhardt
> > > --- On Thu, 5/27/10, mcclurebill@rocketmail.com
> > > wrote:
> > > > From: mcclurebill@rocketmail.com
> > > > Subject: [fairchildclub] Motor Mounts
> > > > Date: Thursday, May 27, 2010, 12:37 PM
> > > > I'm finally getting close to having an
> > engine
> > > > to install in my 24G. I still haven't got
> > a
> > > definitive
> > > > answer on the proper rubber to put between the
> > engine
> > > and
> > > > the motor mount. These have the mount that is
> > integral
> > > with
> > > > the fuselage frame. Upon removing the failed
> > engine I
> > > found
> > > > the rubber to be pieces cut out of tire
> > sidewall. I
> > > have
> > > > since found out from other sources that this
> > may in
> > > fact be
> > > > the right thing to put there. Can anyone with
> > a
> > > similar 24
> > > > tell me what was used in their aircraft?
> > Thanks.
> > > [Non-text portions of this message have been
> > removed]
> > No virus found in this incoming message.
> > Checked by AVG - www.avg.com
> > Version: 9.0.819 / Virus Database: 271.1.1/2910 - Release
> > Date: 06/01/10 01:25:00
> Version: 9.0.819 / Virus Database: 271.1.1/2910 - Release Date: 06/01/10
> 01:25:00
> _________________________________________________________________
> The New Busy is not the old busy. Search, chat and e-mail from your inbox.
> http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_3
Version: 9.0.819 / Virus Database: 271.1.1/2913 - Release Date: 06/02/10
04:57:00
Posted: Wed Jun 02, 2010 2:08 pm
by David Stroud
'Out of curiosity, I wonder if NASM has drawings for the Fairchild FC-2W2 / 71 line of planes.
I struggled for a long time looking for drawings for my Fairchild 51 project and in fact found
them right in my own back yard by "underground" word of mouth. Canada's Aviation Museum
here in Ottawa has a complete set of original blueprints for the 51 and some for the 71 but they
sure don't advertise it.
My Father in Law and I are allowed into the archives by appointment, don the white gloves
then open and photo the old prints in the library, then send them out for print. Some are as far
back as 1927...mostly 28 and 29. It's a moving experience just to touch the old blueprints from
over 80 years ago.
As an aside, it's amazing to see the beautiful handwritten notes on some of them. No keyboards
in those days, done with real ink and the old pens you'd stick in the inkwell. I remember them in
my early school years.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Sent: Wednesday, June 02, 2010 10:40 AM
Subject: Re: [fairchildclub] Re: Master drawing index for the NASM/Smithsonian collection of drawings (1000's)
Hi Marc,
Ed
> should do it. Marc
> Hugh,
> found it.
> Thanks,
> Ed
>> From: wclayman
> > Hugh,
> > Ed
> > From: Jp Lorie
> > Hi Hugh,
> > Thanks,
> > Jp.Lorie
> > Florida
> > applicable.
> > a
> > see if
> > > Thanks again.
> > > Bill McC
> > the
> > engine mounts
> > washer with
> > manufactured from
> > as
> > Drawing
> > drawing is
> > choice.
> > > Hugh Loewenhardt
> > engine
> > a
> > > definitive
> > engine
> > > and
> > integral
> > > with
> > engine I
> > > found
> > sidewall. I
> > > have
> > may in
> > > fact be
> > a
> > > similar 24
> > Thanks.
> > removed]
> 01:25:00
04:57:00
Version: 8.5.437 / Virus Database: 271.1.1/2913 - Release Date: 06/02/10 09:57:00
