--- On Fri, 5/28/10, Hugh Loewenhardt wrote:
> From: Hugh Loewenhardt
> Subject: Re: [fairchildclub] Motor Mounts
fairchildclub@yahoogroups.com
> Date: Friday, May 28, 2010, 7:13 PM
> Hello JP Lorie, No. Drawing 48107 is only
> applicable to Warner 145 powered F-24's with the
> integral style motor mount as specificaly listed on the
> drawing and as cited. Now, on the universal block thread,
> please know that new, reengineered, heavy style upper and
> lower attachment blocks are available from William Spriggs
> (805-657-2460). The new blocks are solid 4130 castings and
> require machining for the bolt holes, a simple job for a
> good machinist with good directions. Also know that there
> are archived threads dealing with the universal blocks on
> the Fairchild Club E-mail List in which Mr. Spriggs
> discusses the availability of the new attachment fittings.
> Hugh Loewenhardt
> --- On Fri, 5/28/10, Jp Lorie
> wrote:
> > From: Jp Lorie
> > To:
> > Date: Friday, May 28, 2010, 1:48 PM
> > Hello Hugh,
> > Does the information you posted below aso apply to the
> 1946
> > 24W-46 with the 165 Warner?
> > Thanks for the info
> > JP. Lorie
> > Florida
> > ________________________________
> > To:
> > Sent: Thu, May 27, 2010 8:58:20 PM
> > Bill, The original engine installation washer for the
> > Warner 145 on Fairchild 24's with integral engine
> mounts
> > is: a 1.250"x1.250"x0.1875"thick washer
> with
> > an 11/32" center hole. The washer is manufactured
> from
> > brake lining material. Dimensions and material are as
> > specified by Fairchild drawing number 48107. Drawing
> > applicability is: C8C,C8E,24G,24J, and 24W9. The
> drawing is
> > available from NASM or I can send you copy. Your
> choice.
> > Hugh Loewenhardt
> > --- On Thu, 5/27/10,
mcclurebill@rocketmail.com
> > wrote:
> > > From:
> > > Subject: [fairchildclub] Motor Mounts
> > > To:
> > > Date: Thursday, May 27, 2010, 12:37 PM
> > > I'm finally getting close to having an
> engine
> > > to install in my 24G. I still haven't got a
> > definitive
> > > answer on the proper rubber to put between the
> engine
> > and
> > > the motor mount. These have the mount that is
> integral
> > with
> > > the fuselage frame. Upon removing the failed
> engine I
> > found
> > > the rubber to be pieces cut out of tire sidewall.
> I
> > have
> > > since found out from other sources that this may
> in
> > fact be
> > > the right thing to put there. Can anyone with a
> > similar 24
> > > tell me what was used in their aircraft? Thanks.
