magneto misfiring
Posted: Wed May 26, 2010 1:27 pm
by m51rs
'Our Ranger c-5 Fairchild had the following problem:
Installed overhauled magneto's. Engine ran perfect. After 40 minutes in the third flight of the day both started to misfire. Got worse by the minute.
Switching to one magneto did not help, even made things worse.
All temps were normal.
Somebody any ideas where to start looking? Magneto's, wiring, switch?
Thanks for your input.
Remko'
Re: magneto misfiring
Posted: Wed May 26, 2010 1:31 pm
by Jim higham
'Look for a stuck valve, do a compression check
Sent: Wednesday, May 26, 2010 2:23 PM
Subject: [fairchildclub] magneto misfiring
Remko
Reply to sender | Reply to group | Reply via web post | Start a New TopicMessages in this topic (1)
Recent Activity: New Members 1New Photos 54
Visit Your Group
MARKETPLACE
Stay on top of your group activity without leaving the page you're on - Get the Yahoo! Toolbar now.
[The entire original message is not included]
Posted: Wed May 26, 2010 1:42 pm
by Bob Webster
'I had one go bad from a bad condenser. Doubtful if both would go bad at the same time though.
They are pretty easy to check generally with an analog VOM.
Remko
Posted: Wed May 26, 2010 2:00 pm
by Airy Millet
'if both mags were overhauled with same components check them...
first look at contacts (if burnt or not), and their springs, and change one condenser on one side...
if still misfiring, look at harness (especially what I call "cigarettes", at the end, and springs making contact with spark plugs).
otherwise as already said, it may not come from ignition, but a stuck valve, or broken valve-spring (never encounter such problem, but...).
Airy
Date: Wed, 26 May 2010 19:23:46 +0000
Remko
Hotmail : Simple et Efficace qui vous facilite la vie? D?couvrez la NOW g?n?ration !
http://www.windowslive.fr/hotmail/nowgeneration/
Posted: Wed May 26, 2010 8:46 pm
by Tom_Downey
'Remove both "P" leads and run it, see if it does the same thing in 40 minutes.
> Remko
Posted: Thu May 27, 2010 5:22 am
by Michael Denest
'Remko,
6-440-C5 mags are timed at 25 degrees BTDC so the magneto installation should be reviewed.  Remove the covers over the points and check that there's a .012 to .015 gap. If not, adjust.  While you are at it, lube the felt oil strip with a thin viscosity oil.  Get number 1 cylinder to 25 degrees BTDC on the compression stroke.  Check the white markers in the mag windows to see if they are aligned.  If not, retime the mags.  Do the right one first as it is easier to do (no impulse coupling).  Once that one is done, do the left one.  Remember that the points opening is delayed by the impulse coupling.  You must make sure that it has snapped over before checking the timing.  I use a buzz box and a TimeRite gage to do this.  Takes me about a 1/2 hour to time both mags.  It will take a little longer with a timing wheel on the prop.
My bet is that both mags are improperly timed.
- Capt. Frank Towns
Flight of the Phoenix
Sent: Wed, May 26, 2010 10:44:53 PM
Subject: [fairchildclub] Re: magneto misfiring
> Remko
Posted: Sat Jun 19, 2010 5:13 pm
by Jim higham
'Remko,
What did you ever figure out for your magneto troubles?
F24R46-108
Remko
Visit Your Group
MARKETPLACE
