'it may be possible, at first modifying the "unlocking cam plate" to lock the steering anytime...and then adapt something to unlock from the cockpit, like a "warbird" !!
but the shimmy, is not really due to the tailwheel itself, but due to geometry!
old tailwheel have shortened springs (coil springs shorten under fatigue along years)...and the front arm, may be redesigne a little bit shorter should be better!
but such mods are useless if there are to much play in the tailwheel assy (especially on the pivot parts, which can be badly worn).
and the "unlocking" angle can be adjust by loosing or thightening the c?ble linked to rudder.
Airy
fairchildclub@yahoogroups.com
burnmcc@aol.com
Date: Sun, 14 Mar 2010 19:19:18 -0400
Subject: Re: [fairchildclub] Tailwheel Question
Thanks. I'd like to modify to lock from the cockpit, until you unlock it, by a cable or the like. Other antiques I've owned were set up that way.
Good to know there might be something out there I can adapt, tho.
Thanks again.
Bill McC
To: fairchildlist
Sent: Sun, Mar 14, 2010 5:10 pm
Subject: RE: [fairchildclub] Tailwheel Question
n UC-61K, there is already a locking pin, but the problem is that it wear year
fter years, then you will have to rebuilt.
The unlocking of those tailwheel happen when full rudder is applied left or
ight!
That's why, when you are landing under high cross wind, you may unlock at the
ame time as correcting the wind!!
It is the locking pin, which make the wheel stearable..unless you apply full
udder, or brake heavily at one side when turning!
As much as possible most of the time we try not to use brakes at all, as they
re heating quite rapidly, and loosing efficiency!
Airy
o:
rom:
burnmcc@aol.com
ate: Sat, 13 Mar 2010 22:52:46 +0000
ubject: [fairchildclub] Tailwheel Question
I see Fairchild 24 tailwheel issues have been a high interest topic in the past.
'm wondering if there is a mod to add a locking pin that would make it stay
riented straight ahead for takeoff and landing? It seems that would be a way to
top the shimmy problems.
hanks.
__________________________________________________________
otmail et MSN dans la poche? HOTMAIL et MSN sont dispo gratuitement sur votre
?l?phone!
ttp://
www.messengersurvotremobile.com/?d=Hotmail
Individual Email | Traditional
Hotmail arrive sur votre t?l?phone ! Compatible Iphone, Windows Phone, Blackberry, ?
http://www.messengersurvotremobile.com/?d=Hotmail
