For MF information and frustration reduction
Posted: Sat Jan 30, 2010 9:37 am
'MF:
Not sure what the initials are but here goes:
While I sense your frustration, you need to speak with the FAA-! While there is NO question about some "junk" being peddled as used aircraft, the impact of putting too much information in an aircraft or pilot log is the "wrath" of certain FAA Inspectors. I am a retired ASI Manager and the quality of folks the FAA hires is clearly lacking-!
I would suggest you also obtain and read the appropriate FAR as it pertains to "continued airworthiness" of Part 23, CAR 3 or other antique or vintage aircraft. The early days of our industry had little regulatory oversight and that we had was with qualified and competent bureaucrats as opposed to those we have employed within the FAA today-!
There is NO "regulatory" requirement to "annual" or conduct an annual inspection unless there is some "intent" for flight in that aircraft. You also need to know that there is NO regulatory requirement to completely rebuild an engine at "Recommended" overhaul intervals unless that aircraft is used in "commercial" service. What most of us do with old vintage and antique aircraft is Part 91 operations NOT FAR Part 135 or 121.
DR
Previous owner F24 N81229
Own/operate: C195 N166VN, C182A N766VN, OTW N34349
Dick Russell, ATP CFII
Nebraska Aviation Hall of Fame
Vietnam Sight-seeing operations 1966-1975
www.Russellaire.com www.councilofchiefs.net www.Hardyaviationins.com
Check six and fly safe...
DR
