'I remember when I first saw the heat box and how I was puzzled too. The
heat comes from the #6 cylinder and works quite well despite our prejudices
towards exhaust-muff heaters. Interestingly, the first engine on my
experimental Great Lakes came from a Grumman Widgeon and the carb heat came
from a plenum that went under the engine to a port on the exhaust shroud. A
convention looking cylindrical mixer box provided the heat to the carb. No
filter however, so I changed to the PT box.
You'll need the o'haul manual for reinstalling the new jugs and timing the
cam - ESSCO has them. Another surpirse - no timing marks!!
Fret not, just follow the manual.
Can't help with the cabin heat 'cause I aint got no cabin.
Ranger Mike
Sent: Sunday, December 20, 2009 7:14 PM
Subject: [fairchildclub] New owner F24R-46 needs carb heat info
>I just acquired a F-24 with A 200 hp. Ranger. It hasn't been flown since
>1992 when the previous owner removed a pair of cylinders. I'm doing well
>figuring the pile of parts out, but what does the engine do for carb heat?
>I found the flap on the airbox, but no heat muffs??? Also, where do you get
>cabin heat? I have the valve on the firewall, nothing else.
