'Ummm, Mike is correct about chroming the cylinders but I would do that if there was no other alternative. Ranger TBO's usually run about 600 hours. If I were to stash extra parts, it would be a set of .010 over pistons and rings. A standard cylinder dimension is 4.125 inch. As long as the cylinder can be gound to the next oversize dimension, you are ok. Fit the rings for a minimum of .018 end gap. For oil consumption, stay away from the Warner mod, it is not approved for the Ranger. Proper ring fit is the key to 1 qt./hr.
Machining pistons is not a good idea from the standpoint of the ring grooves which will be too far undersize to support the ring.
Speaking of oil consumption, repouring the bearings and line boring to a smaller dimension from the .004 to .005 inch stated in the overhaul manual is considered a Major Repair and requires FAA 337 approval.
- Capt. Frank Towns
Flight of the Phoenix
fairchildclub@yahoogroups.com
Sent: Sun, December 20, 2009 10:37:04 PM
Subject: [fairchildclub] Re: Ranger Piston Sizes
Thanks Mike,
I never thought of that. This is good to know.
Jim Long
--- In fairchildclub@ yahoogroups. com, "Mike Danielle" wrote:
> ...or you can have the cylinders plated down.
> Ranger Mike
> From: "mileslong2k"
> Sent: Sunday, December 20, 2009 6:32 PM
> Subject: [fairchildclub] Ranger Piston Sizes
> > If a person were to rat hole parts for a future Ranger engine rebuild, or
> > cylinder upgrade (200 HP piston use) would it be wise to find Standard
> > pistons, or say, .010, or .020" pistons? You can always have the oversized
> > pistons machined down, right?
> > Jim Long
> > Yahoo! Groups Links
