tail wheel problem update
Posted: Thu Dec 10, 2009 2:11 pm
'Thank you all for the helpful feedback on my tail wheel problem.
Finally got the wheel apart. The valve stem is vulcanized onto the tube, offset from the center, and straight, but too long. A half inch shorter would be great. The tube looks like it was healthy, but it no longer is after my crude removal strategy. It wasn't the proper one anyway, so I'm ordering a replacement. Both banaire.com and Dresser have what look like appropriate ones on their websites. I'll talk with them before ordering.
Getting the tire separated from the hub was a problem. There's gotta be a simpler way. If someone has some hits on assembly/disassembly that would be appreciated.
My wheel did not have a cover plate for the valve stem side. But the hub does have a grove around the inside edge of the hub where the outside diameter of a cover plate would go. Fabricating a cover plate with valve access hole looks pretty straightforward. I'm not sure about how to come up with a snap ring yet.
Jim Long ? I'll be glad to take some photos of the hub and wheel when I get things cleaned up, though the hub looks like its been through some hard times.
Again - thank you all for you help. It is greatly appreciated. Actually, this is exactly what I've found to be so good about this news group.
Charles Mueller'
Charles Mueller'
