Page 1 of 2
Ranger 440 engine testing & rebuild
Posted: Sun Nov 08, 2009 7:49 pm
by docarnie
'Can anyone help me with a problem with a couple of Ranger 440 engines. Both have been rebuilt, one was rebuilt this past year the other 8 years ago and was brought out of storage to be installed in a PT-19 which was recently finished by the Spirit of Tulsa (OK) Wing of the CAF. The issue is that both engines loose oil pressure once they are up to operating temperature. The oil pressure falls to between 40 & 45 psi. If you need more details I will refer you to the A&P's who are trying to solve this problem.
Does any member of this forum know of an engine shop that can help us figure this problem out?
Thank you in advance,
Arnie Angelici'
Re: Ranger 440 engine testing & rebuild
Posted: Sun Nov 08, 2009 10:51 pm
by Mike Danielle
'My Ranger will lose some pressure after the oil warms up. That's normal.
Just set the pressure to the normal operating range while the oil is warm.
High oil pressure doesn't hurt anything while the engine is warming. You
know how the pressure relief valve works and how to adjust the oil pressure,
right?
Ranger Mike
Sent: Sunday, November 08, 2009 5:48 PM
Subject: [fairchildclub] Ranger 440 engine testing & rebuild
> problem.
> Arnie Angelici
Posted: Mon Nov 09, 2009 2:41 am
by Airy Millet
'moreover, oil pressure are to be record at cruising rpm!!
(low pressure at ground iddle is quite normal when warm!).
Airy
Date: Sun, 8 Nov 2009 20:50:39 -0800
Subject: Re: [fairchildclub] Ranger 440 engine testing & rebuild
right?
Ranger Mike
> problem.
> Arnie Angelici
Nouveau Windows 7 : Simplifiez votre PC ! Trouvez le PC qui vous convient.
http://clk.atdmt.com/FRM/go/181574580/direct/01/
Posted: Mon Nov 09, 2009 6:15 am
by Bob
'Arnie,
I agree with Mike. My oil pressure starts at 67 when cold, then drops to 55 once the oil is warm. Even when I leave a heated hangar with pre-heated oil, pressure is a bit higher until oil gets hot.
Increase your oil pressure by 10-15 pounds and you should be fine.
1939 Fairchild 24K
Webster MN USA
> Arnie Angelici
Posted: Tue Nov 10, 2009 8:47 am
by docarnie
'Dear Mike,
I have to confess that I am only one of the pilots. I try not to do anything that would make the crew chief or the mechanic mad at me, especially if it was a preventable issue, i.e. like flying with low oil pressure at normal operating temperature. I will ask our mechanic about the oil pressure relief valve.
Thank you for the tip,
Arnie
> right?
> Ranger Mike
> From: "docarnie"
> > problem.
> > Arnie Angelici
> > Yahoo! Groups Links
Posted: Tue Nov 10, 2009 9:10 am
by Bill Johnson
'Mike:
OK, I'll ask. How does the oil pressure relief valve work, and how do
you adjust it?
Bill
[mailto:fairchildclub@yahoogroups.com] On Behalf Of docarnie
Sent: Tuesday, November 10, 2009 8:45 AM
Subject: [fairchildclub] Re: Ranger 440 engine testing & rebuild
Dear Mike,
Arnie
, "Mike Danielle"
normal.
warm.
You
pressure,
> right?
> Ranger Mike
> From: "docarnie"
engines.
years
was
issue
operating
need
this
> > problem.
us
> > Arnie Angelici
> > Yahoo! Groups Links
Re: Oil pressure & relief valve was: Re: Ranger 440 engine testing
Posted: Tue Nov 10, 2009 10:15 am
by Airy Millet
'simply an helicoidal spring pushing the valve on its seat!
adjustable by screwing or unscrewing...
By the way, does anybody knows the "k" constant of this spring (or load/length ratio)...
Maybe in order to rebuild brand new ones...
Airy
Date: Tue, 10 Nov 2009 09:09:41 -0600
Subject: RE: [fairchildclub] Re: Ranger 440 engine testing & rebuild
Mike:
you adjust it?
Bill
Dear Mike,
Arnie
, "Mike Danielle"
normal.
warm.
You
pressure,
> right?
> Ranger Mike
> From: "docarnie"
engines.
years
was
issue
operating
need
this
> > problem.
us
> > Arnie Angelici
> > Yahoo! Groups Links
Nouveau Windows 7 : Trouvez le PC qui vous convient. En savoir plus.
Posted: Tue Nov 10, 2009 11:28 am
by Michael Denest
'Setting oil pressure is a very simple operation.  Detailed instructions can be found in the Ranger maintenance manual.  The maximum and minimum oil pressures are found in the table of limits in the appendix at the back of the book.
READ THE BOOK GUYS!!!
- Capt. Frank Towns
Flight of the Phoenix
To: fairchildlist
Sent: Tue, November 10, 2009 11:15:09 AM
Subject: RE: [fairchildclub]Oil pressure & relief valve was: Re: Ranger 440 engine testing & rebuild
Airy
Mike:
you adjust it?
Bill
Dear Mike,
Arnie
, "Mike Danielle"
normal.
warm.
You
pressure,
> right?
> Ranger Mike
> From: "docarnie"
engines.
years
was
issue
operating
need
this
> > problem.
us
> > Arnie Angelici
> > Yahoo! Groups Links
Posted: Tue Nov 10, 2009 2:39 pm
by Jack Threadgill
'I don?t know many of the folks that own or fly aircraft with Ranger engines
nor do I know how long they have been operating the engines. I suspect
there are some that have yet to assemble complete sets of instructions and
manuals. Many tasks are very simple and easy once they have been done.
I found in the L-440-1 and -3 Operating Instructions dated 1942 that the
normal operating Max oil pressure is 70 psi and Min is 50 psi with a desired
pressure of 60 psi. The Min idle pressure is 15 psi.
I have not found any oil pressure adjustment instructions in the Service
Instructions for the L-440-1, -3 and -5, nor in the Overhaul Instructions.
I would like to thank Mike Danielle that sent me the following simple
instructions of setting the oil pressure on the Ranger engines.
There's a large, elongated cap (like an acorn nut) located on an angle just
beside the oil screen cover on the top right rear of the engine. Should be
safety-wired. Remove the cap and you will see its threaded base is a
slotted screw. This is the oil pressure relief valve adjustment. Screw it
in and the oil pressure will increase, screw it out and the pressure will
decrease.
I adjust mine to show about 55psi at cruise rpm with the oil warmed up.
When cold, the pressure might be as much as 65psi but it comes down within a
few minutes as the oil warms up.
Maybe this will be helpful to other new guys like me to Ranger ownership.
Thanks Mike Danielle for your understanding and help. It is quite simple
once one has done it.
Best wishes,
Jack
Jack Threadgill
1602 Brook Hollow Dr
Bryan, TX 77802
979-779-7155
threadgl@suddenlink.net
On Behalf Of Michael Denest
Sent: Tuesday, November 10, 2009 11:28 AM
Subject: Re: [fairchildclub]Oil pressure & relief valve was: Re: Ranger 440
the book.
- Capt. Frank Towns
To: fairchildlist
Airy
Mike:
you adjust it?
Bill
yahoogroups.com
Dear Mike,
Arnie
yahoogroups.com
, "Mike Danielle"
normal.
warm.
You
pressure,
> right?
> Ranger Mike
> From: "docarnie"
engines.
years
was
issue
operating
need
this
> > problem.
us
> > Arnie Angelici
> > Yahoo! Groups Links
http://clk.atdmt
Posted: Tue Nov 10, 2009 3:18 pm
by Bill Johnson
'Jack,
That kind of information is both extremely helpful and very much appreciated.
Thank you very much for your help. I would like to think I might return the favor one day, but you are way ahead of me.
I trust you are enjoying your PT. It's a beauty.
Bill Johnson
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of Jack Threadgill
Sent: Tuesday, November 10, 2009 2:38 PM
I don't know many of the folks that own or fly aircraft with Ranger engines
decrease.
Best wishes,
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com ]
the book.
- Capt. Frank Towns
To: fairchildlist
Airy
Mike:
you adjust it?
Bill
yahoogroups.com
Dear Mike,
Arnie
yahoogroups.com
, "Mike Danielle"
normal.
warm.
You
pressure,
> right?
> Ranger Mike
> From: "docarnie"
engines.
years
was
issue
operating
need
this
> > problem.
us
> > Arnie Angelici
> > Yahoo! Groups Links
http://clk.atdmt
