Page 1 of 2
F-24 Master Brake Info
Posted: Wed Oct 21, 2009 8:48 am
by Seifert
'Thanks Bob, Tom, and Jamie for the brake info.
Since my cylinders are corroded and will need to be corrected inorder to be rebuilt; I will let you all know what I wind up doing to fix the problem. I've been studying the way the Fairchild master brake cylinders were built and have decided that fabricating new stainless steel cylinders for the master brake would not be impossible, if I can't find someone that can sleeve them with stainless sleeves.
Thanks again.
Rich Seifert
Re: F-24 Master Brake Info
Posted: Wed Oct 21, 2009 11:56 am
by mileslong2k
'Hello,
Any chance the members of this forum would be able to see pictures of this progress? I am collecting photographs of Fairchild 24's and their related parts when they come up in the photo section of this forum. Thanks.
Jim Long
Santa Rosa, CA
> Thanks again.
> Rich Seifert
Posted: Wed Oct 21, 2009 12:55 pm
by Jack Threadgill
'I would hope so. I would like to see them.
Jack
N1941N
Jack Threadgill
1602 Brook Hollow Dr
Bryan, TX 77802
979-779-7155
threadgl@suddenlink.net
On Behalf Of mileslong2k
Sent: Wednesday, October 21, 2009 11:56 AM
Subject: [fairchildclub] Re: F-24 Master Brake Info
Hello,
Jim Long
Santa Rosa, CA
> Thanks again.
> Rich Seifert
Posted: Wed Oct 21, 2009 3:15 pm
by Cy Galley
'Look thru the AACA Antique Auto Ads or Hemmings. There are people that resleeve brake parts on a regular basis.
www.eaa75.com
To: Fairchild Club
Sent: Wednesday, October 21, 2009 9:48 AM
Subject: [fairchildclub] F-24 Master Brake Info
Thanks again.
Rich Seifert
Posted: Wed Oct 21, 2009 4:47 pm
by Jack Threadgill
'Cy, you have got to be a friend of Neil Pobanz.
Jack
PT-19
N1941N
Jack Threadgill
Bryan, TX 77802
979-779-7155
On Behalf Of Cy Galley
Sent: Wednesday, October 21, 2009 3:15 PM
Subject: Re: [fairchildclub] F-24 Master Brake Info
www.eaa75.com
To: Fairchild Club
Thanks again.
Rich Seifert
Posted: Wed Oct 21, 2009 5:35 pm
by Cy Galley
'Yes he worked for me at Oshkosh and Annuals my plane.
Cy
Sent: Wednesday, October 21, 2009 5:47 PM
Subject: RE: [fairchildclub] F-24 Master Brake Info
Jack
PT-19
N1941N
Jack Threadgill
Bryan, TX 77802
979-779-7155
www.eaa75.com
To: Fairchild Club
Thanks again.
Rich Seifert
Re: F-24 Master Brake Info/Chat
Posted: Wed Oct 21, 2009 7:53 pm
by Jack Threadgill
'Cy, I suspected that with your Air Venture relation. Neil is a great guy
and a tremendous asset to the American Bonanza Society as their Chief
Technical Advisor.
What kind of plane do you have that Neil annuals for you.
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
Sent: Wednesday, October 21, 2009 5:36 PM
Cy
Jack
PT-19
N1941N
Jack Threadgill
Bryan, TX 77802
979-779-7155
threadgl@suddenlink .net
yahoogroups.com]
www.eaa75.com
To: Fairchild Club
Thanks again.
Rich Seifert
Posted: Wed Oct 21, 2009 8:55 pm
by Cy Galley
'I am presently rebuilding a 14-13-2 Bellanca
Sent: Wednesday, October 21, 2009 8:48 PM
Subject: RE: [fairchildclub] F-24 Master Brake Info/Chat
Technical Advisor.
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
Cy
Jack
PT-19
N1941N
Jack Threadgill
Bryan, TX 77802
979-779-7155
yahoogroups.com]
www.eaa75.com
To: Fairchild Club
Thanks again.
Rich Seifert
Posted: Sat May 08, 2010 9:11 pm
by ellengstarr
'Rich,
Wondering what you were able to come up with regarding sleeving your cylinders? I have a 24W with 1 1/4" bore. Believe they are original type.
One place looked at them and said the casting would be too thin after machining for the sleeve. So I am back to square one!
Thanks.
Roger Starr
> Thanks again.
> Rich Seifert
Posted: Sat May 08, 2010 10:23 pm
by Seifert
'Hi Roger
I did have Sierra Specialty Automotive (530-283-1886) sleeve my master cylinders. Mine are for a 1946 F-24W, which is still a long way from flying but I have no doubt they will work just fine. My cylinders are not castings. They were called tin can master cylinders and were an assembly of machined steel cylinder, sheet metal can type reservoir, and sheet metal attach fittings all brazed together. The original ID plate attached to the cylinders identified them as Wagner Electric Corporation # FE2014. Sierra Specialty Automotive machined out the old cylinders and installed the brass sleeves and I installed the brake kits. I think Joe at Sierra Specialty Automotive said the cylinders are 1937 - 41 Chrysler master brake cylinders. I am happy with their work but I did have to heat and streach out the snap ring to securily retain all the innerds. You do have to pick and choose between the original brake parts and the replacement parts. I used a NAPA #1 brake kit for the rubber parts but retained the original brass pistons, and thin brass washers which act as check valves. The remainder of the kit was discarded. The machining cost was $110.00 each. I thought I took pictures of the cylinders before installing the brake kits but have been unable to find them so far. I will be happy help If you have any other questions.
Sent: Saturday, May 08, 2010 8:10 PM
Rich,
Thanks.
Roger Starr
> Thanks again.
> Rich Seifert
