bleeding expander tubes
Posted: Tue Oct 06, 2009 3:33 pm
'Is it worth the effort to try to fill the Hayes brake expander tubes with fluid, thereby expelling all the air in them, before installing the tubes?
I'm getting ready to get my PT-26s brakes back on and noted the stem for the tubes is not near the top where air would tend to accumulate.
Also - I just reviewed the past couple years messages on the Hayes brakes and the landing gear struts and have concluded that using DOT 5 in the brake system and 5606 in the landing gear struts is a good way to go. Also using something like TiteSeal, especially on the copper gaskets on the banjo fittings, will reduce the likelihood of brake fluid leaks. Do these ideas sound reasonable?
Is there something else I should know about before wading into this?
Charles'
Charles'
