'sorry, but the camshaftcase is pressurized by the big oil link tube, and by the gear link too...
that's also wy such engine do have oil consumption through valve guides, as oily vapors are going this way under pressure too...
so, the only way to drain the oil from separator is in an atmosphere pressure bottle, or so...
Airy
fairchildclub@yahoogroups.com
checkpoint2@comcast.net
Date: Thu, 11 Jun 2009 19:43:36 -0400
Subject: RE: [fairchildclub] air oil separator
Better to let the drain from oil separator into a non
pressurized crankcase area, such as the cam box Bob Haas
On Behalf Of Airy Millet
Sent: Thursday, June 11, 2009 2:42 PM
To: fairchildlist
Subject: RE: [fairchildclub] air oil seperator
On a F-24 I tried to have one on the firewall on the top, in order to make
the original engine vent pasing through the separator, thus having the
return line from the separator higher level than the oil tank, and being
able to drill a return hole on top of the oil tank (tiny diameter regarding
the vent tube diameter not to pressurize the oil tank with engine crankcase
pressure and vapours.
Airy
Date: Thu, 11 Jun 2009 18:32:16 +0000
Subject: [fairchildclub] air oil seperator
Where is the best place to mount an air oil seperator on a PT-19 . Should
the return be in tha tank vent?
Michael
__________________________________________________________
Téléphonez gratuitement à tous vos proches avec Windows Live Messenger !
Téléchargez-le maintenant !
http://www.windowsl
ive.fr/messenger/1.asp
Checked by AVG -
www.avg.com
Version: 8.5.339 / Virus Database: 270.12.63/2169 - Release Date: 06/11/09
05:53:00
Inédit ! Des Emoticônes Déjantées! Installez les dans votre Messenger !
http://www.ilovemessenger.fr/Emoticones/EmoticonesDejantees.aspx
