'Folks,
I have a new firewall (Sandwich type) and am at a loss (at the moment) as to
how the Throttle and Mixture control RODS are sealed as they pass through
the
firewall.
I have scoured the 'net' for photo's and have got close but not close enough
to show detail.
My controls are set in the instrument panel at an angle (sloping upward as
viewed from the cockpit) on a small sub-panel.
If any of you Argus III (UC61K)owners could give me a clue I would be very
grateful - maybe a photo?? to coxs.gorrel@virgin.net.
A Happy new year to all
Frank cox
UC61K HB751 G-BCBL'
Re: F24 UC61K R46 Engine controls
'Unless something was done differently between the civilian and Military birds, there was no seal. There was a oblong rubber grommet that lined the hole. The only problem that I saw was it was that it had approximately a 1/2" groove versus the more standard 1/16" groove. I probably will just locate some 3/4" thick neoprene rubber, and cut out a new one on a lathe. My old one is still in tact, but probably not servicable.
I will be keeping my eye out for somekind of a boot, from motorcycle, or small equipment uses, that may fit the bill.
Sent: Monday, December 29, 2008 6:54 AM
Subject: [fairchildclub] F24 UC61K R46 Engine controls
Folks,
the
firewall.
to show detail.
Frank cox
UC61K HB751 G-BCBL
'PT-19's use a cloth boot around the mixture and throttle rods.
"He's crazy Lew, he builds toy airplanes".
- Capt. Frank Towns
Flight of the Phoenix
Sent: Monday, December 29, 2008 1:23:00 PM
Subject: Re: [fairchildclub] F24 UC61K R46 Engine controls
- Capt. Frank Towns
To: fairchildclub@ yahoogroups. com
Folks,
the
firewall.
to show detail.
grateful - maybe a photo?? to coxs.gorrel@ virgin.net.
Frank cox
UC61K HB751 G-BCBL
F.J. & D.A. Cox
'Bob and Mike - Thank you for that useful information.
It appears that there could be a difference between the civil and military throttle controls in that the civil version only had rod control for the mixture - and cable for the throttle.
However with 2 rods one of which has some vertical and horizontal movement relative to the firewall (there is a UV joint behind the inst. panel) I need to come up with a solution and your inputs give me food for thought - Thanks
Best regards
Frank
Best regards
Frank
Sent: Monday, December 29, 2008 9:59 PM
- Capt. Frank Towns
Folks,
the
firewall.
to show detail.
Frank cox
UC61K HB751 G-BCBL
rangerrobertmn
'--- In fairchildclub@yahoogroups.com, Michael Denest
Could you post a photo of the cloth boot?
Thanks.
Fairchild 24K
Sky Harbor Airpark
Webster, MN'
Mike,>
> Mike
Thanks.
Fairchild 24K
Sky Harbor Airpark
Webster, MN'
