Fuel Pipes to fuel selector valve compression fittings
Posted: Wed Dec 03, 2008 11:19 am
by Frank Cox
'Folks,
I'm having a problem with sourcing the small brass compression fittings
on the ends of the aluminium fuel lines (2 in and 1 out)where they
enter and exit the fuel on/off valves in my UC61K rebuild project. I
cannot rescue the old ones as they have been compressed around the
corroded alloy pipes to such an extent that the internal diameter of
the pipe is reduced. Even if I did get them off they would not fit over
the new pipe.
I'd be interested to know of any method anyone might have used to
overcome the problem; possibly with a suitable combination of adaptor
fittings or knowledge of a secret supplier/manufacturer of these
compression fittings!
With many thanks and Compliments of the season to everyone.
(UC61K G-BCBL)'
Re: Fuel Pipes to fuel selector valve compression fittings
Posted: Wed Dec 03, 2008 8:58 pm
by Bob Etter
'You might try it. I took 12 double flair compression rings (air conditioner stuff), and carefully cut one of the flairs off. It gave me a single flair on one side and a squared off shoulder on the other side. I used a lathe and put the compression ring in the jaws of the head stock, but backed it up with a hardened rod, so I wouldn't distort the ring. Out of the 12 rings, I got the 8 really good ones that I wanted.
Sent: Wednesday, December 03, 2008 9:19 AM
Subject: [fairchildclub] Fuel Pipes to fuel selector valve compression fittings
Folks,
the new pipe.
(UC61K G-BCBL)
Posted: Wed Dec 03, 2008 10:02 pm
by ROBERT COON
'Frank,
We may have some new (old) fuel shut off valves still in cloth bags complete with original compression fittings.  Would you be interested?
Bob Coon
Jim Chybicki
UC61-K
HB-690
--- On Wed, 12/3/08, Bob Etter wrote:
Subject: Re: [fairchildclub] Fuel Pipes to fuel selector valve compression fittings
Date: Wednesday, December 3, 2008, 8:56 PM
Folks,
the new pipe.
fittings or knowledge of a secret supplier/manufactur er of these
(UC61K G-BCBL)
Posted: Thu Dec 04, 2008 3:37 am
by F.J. & D.A. Cox
'Bob 'C'
- Thank you for the offer but my fuel cocks are both in good shape - I think it would be overkill to replace them for the sake of the compression fittings - however if I am totally stuck may I come back to you?
Bob 'E'
- Sounds like an excellent 'way ahead' - I'll attempt to find such fittings - could be difficult over here as we have gone metric! - I'll work on it.
Thanks to both for such rapid response
Sent: Thursday, December 04, 2008 4:01 AM
Frank,
Bob Coon
Jim Chybicki
UC61-K
HB-690
Folks,
the new pipe.
(UC61K G-BCBL)
Posted: Sat Dec 06, 2008 7:12 pm
by ROBERT COON
'Frank,
Not a problem.  Good luck.  Anything else we can help you with let us know.
Seasons Greetings.
Bob Coon
Jim Chybicki
HB-690
UC-61K
Keep em flyin
Date: Thursday, December 4, 2008, 3:37 AM
Bob 'C'
Bob 'E'
Frank,
Bob Coon
Jim Chybicki
UC61-K
HB-690
Folks,
the new pipe.
(UC61K G-BCBL)
