fairchildclub@yahoogroups.com
Sent: Friday, October 31, 2008 9:51 PM
Subject: Re: [fairchildclub] Some Fairchild wing data found.
Hi Bob
I see what you mean. The wing appears to taper gradually. I may have to pull dimensions from a good rib to get the info. One thing still bothers me though. It appears that all the rib drawings lack verticle coordinate data. This makes me think the info I need, must reside on another drawing. Maybe a drawing of airfoils.
Sent: Friday, October 31, 2008 6:02 PM
I think that you won't find what you are looking for, as Clark Y or N-22. It is going to be something between the basic airfoil and wing tip. The only part of that rib that looks anywhere normal to my eyes, is the area aft of the rear spar. If you look at 44254 (Butt rib) and 44185 (Fuel tank area), the chord line is pretty close to the bottom of the ribs. When you get out to 4443, you can see that the bottom of that rib is maybe 1/2" (at the front spar) above the chord line. ie the wing has started to taper somewhere slightly inboard of the 4443 rib.
Also what I don't see in the drawing, the doublers on the top & bottom cap strips show no indication that they are tapered. See the nose of the 44254 rib on the CD. There it indicates tapering.
To: Fairchild Club
Sent: Thursday, October 30, 2008 8:13 PM
Subject: [fairchildclub] Some Fairchild wing data found.
OK guys! Upon checking through my F-24 manuals, I found the Fairchild 24 used a Navy N-22 airfoil; but I'm still looking for coordinates for this airfoil. I'm checking internet sites on airfoils now.
I volunteered to help an F24 friend and will be doing some wing repair. I have been searching the CD for the info and found the rib 4443 that needs the TLC, but would like to know the airfoil number to check against the ploted drawing. Is there anyone out there with this info?
