'Contact Clayton buy the whole project, his wings are ready to
assemble.
1936 FAIRCHILD 24G PROJECT ? $9,000 ? AVAILABLE FOR SALE ? 1936
Fairchild 24G project less FWF- Complete except for brakes and wheel
pants. Needs new wood , and some welding repair. Most of the wing
ribs have been built, but the wings need to be assembled. Located in
Yakima, WA. Contact Clayton Fuehrer owner phone 509.949. 4346. ?
Contact Clayton D. Fuehrer, Owner - located Yakima, WA USA ?
Telephone: 509-949-4346 . 509-972-3378 . ? Fax: 509-972-3294 ?
Posted September 19, 2008
The Ad and pictures are on Barnstormers.com
-- In
fairchildclub@yahoogroups.com, "Rich Seifert"
> Hi Robert
> That is the correct wing rib. I have a few dimensions from
the 4443 rib drawing, but the old rib on this wing was not built
correctly and didn't fit worth beans. There is considerable taper
toward the wing tip along the top capstrip of this rib making
pulling dimensions difficult. The few drawing dimensions are from
the centerlines of the spars to the inner surface of the top and
bottom capstrips. That is likely the best method for dimensioning
if someone can't identify the airfoil. Lets give it a few days
Robert and see if someone can name that airfoil. If they can't; I
will definately take you up on your offer.
> Thanks for responding.
