--- On Fri, 8/29/08, vampsqu wrote:
Subject: [fairchildclub] Re: former plans for c8c ?
fairchildclub@yahoogroups.com
Date: Friday, August 29, 2008, 5:37 AM
--- In fairchildclub@ yahoogroups. com, Hugh Loewenhardt
> Tim,
> Yes, like you I had to make new upper and lower formers and I must
tell you up front, it is no walk in the park to do it correctly
without detailed blueprint or manufacturing information which does
not exist. Another C8C restorer was able to pull a set of the former
shapes from his original C8C upper and lower fuselage fairing
assemblies which I then used to make new fairing assemblies for my
ship. The new fairing assemblies were the first things I built using
the fuselage frame as a building jig. The crossing points and angles
for new stringers were located by running lines for each stringer
from pre-determined fore and aft points. The fairing assemblies were
removed after completion and stored at which time I proceeded with
cleaning and preserving the fuselage structure and build up of the
airplane.. The patterns of the original fairing assemblies were
passed along to Roman Mitura in Canada for his C8C project with the
intention and
> understanding that he would recreate them on a computer format and
return the originals to me. I suggest you contact Roman Mitura (613)
254-5421 and determine the status of his computer effort and the
patterns.
> Hugh
> --- On Sat, 8/23/08, vampsqu wrote:
> From: vampsqu
> Subject: [fairchildclub] former plans for c8c ?
> To: fairchildclub@ yahoogroups. com
> Date: Saturday, August 23, 2008, 9:47 AM
> Hello again.....
> I heard a rumor that there might be a cd-rom with fairchild wood
> blueprints on it -- specificly the outlines for tracing out new
> replacement formers. We are missing the old wood from the formers
> on top of the fuse. It is a 34 model F-24 c8c. It has shorter top
> formers than the later models.
> Hugh, did you make new ones for your c8c ????????
> We will be finnishing the fuse blasting and priming soon so the
formers
> are looming near on the horizon of things to do !
> Thanks in advance for any ideas !
> Tim in Orlando
> Hugh: thanks for the info.
You mentioned that you sort of "transfered" the shape from the
formers of an existing plane (covered I assume) to your paper to
generate the shape of the formers. Did you use some kind of duplicator
to transfer the curves---- did you invent a clever way to do it ????
My cousin may be going out of town to visit one that is restored so
I am interested in ways it might be done which wouldn't have ANY
impact on the fabric or finnish of a restored plane. Can you give me
some hints from your experiencees ???????????? ?
Also you refered to "fairings" .....
we are still learning the proper names for all the faircild's parts
were you calling the fuselage formers fairings ? Or are the fairings
the metal covered wood parts on the landing gear struts ??????
I'm not sure what stuff is called on this thing yet !
Thanks.... Tim in Orlando !!
