Ranger engine crankshaft oil gally plugs.
Posted: Sat Jun 21, 2008 3:32 pm
by John Ellis
'Hi to all,
The plugs that go into the crankshaft all leak. I have tried just about everything, including making new plugs oversize, freezing the plugs and heating the shaft for the installation.
This worked for about 200 hours.
I have lowered the oil pressure to 35 lbs, used all types of sealer and still get leaks. Oil consumption went from about a pint per hour to 1 1/2 quarts per hour the last couple of times it flew. I feel sure a plug turned loose again.
Does anyone have a fix that works?
John Ellis a/p
Re: Ranger engine crankshaft oil gally plugs.
Posted: Sat Jun 21, 2008 6:24 pm
by Curt Kinchen
'I had an engine where the plugs were machined for o-rings. They were tight, and I'm pretty sure they didn't
leak much if anything. Engine still used between 1 and 1.25 qts/hour. If it doesn't get any worse than where you are right now I wouldn't worry about it. Curt Kinchen
To: fchld@bevcomm.net; fairchildclub@yahoogroups.comFrom: johnee35@att.netDate: Sat, 21 Jun 2008 16:36:02 -0500Subject: [fairchildclub] Ranger engine crankshaft oil gally plugs.
Hi to all,The plugs that go into the crankshaft all leak. I have tried just about everything, including making new plugs oversize, freezing the plugs and heating the shaft for the installation.This worked for about 200 hours.I have lowered the oil pressure to 35 lbs, used all types of sealer and still get leaks. Oil consumption went from about a pint per hour to 1 1/2 quarts per hour the last couple of times it flew. I feel sure a plug turned loose again.Does anyone have a fix that works?Thanks,John Ellis a/p[Non-text portions of this message have been removed]
Posted: Sun Jun 22, 2008 8:53 am
by WILLIAM SPRIGGS
'Hi John: I had the same problem with leaking plugs, but talking to the late Ike Fernandes obtained the fixture to machine the groves in the plugs to insert o-rings. It's a tight job to get the plugs back into the crank with the o-rings installed, but I think this will cure the problem. Let me know if you would like a set of machined plugs. Bill Spriggs waspriggs@msn.com
To: fairchild club ; fairchildclub@yahoogroups.com
Sent: Saturday, June 21, 2008 2:36 PM
Hi to all,
John Ellis a/p
Posted: Sun Jun 22, 2008 6:02 pm
by Michael Denest
'Clean the mating surfaces and apply red Locktite.  How many hours on the engine?  Your engine should be running at least 60# at power, 35 is way too low.
Quando omni flunkus moritati
- "Red" Green
Sent: Saturday, June 21, 2008 5:36:02 PM
Hi to all,
John Ellis a/p
Posted: Sun Jun 22, 2008 6:58 pm
by John Ellis
'Mike,
Rebuilt the engine 140 hours ago. re-poured all the bearings, line bored mains to fit shaft with .0025 clearance, cut rod bearings same clearance.
At 35 pounds or 60 pounds, your still have only the oil in the clearance area to protect shaft and bearings. The more pressure, the more oil goes throught same space to be controlled by the rings.
I used Locktite # 603 to seal the plugs. Worked very well until a few flights back, consumption went to 1 1/2 quarts per hour from quart every 2 1/2 hours. Lowest compression is 74/80, with engine running good.
I called Locktite when doing the overhaul, they recommended the # 603. What number are you using?
John
Sent: Sunday, June 22, 2008 7:02 PM
Subject: Re: [fairchildclub] Ranger engine crankshaft oil gally plugs.
- "Red" Green
Hi to all,
John Ellis a/p
Posted: Mon Jun 23, 2008 5:45 am
by Michael Denest
'I believe we're using the same Locktite.  Let me ask you this question.  What are your cylinder dimensions and what is the ring end gap fit and are the cylinders chromed?  Personally, I think that 1 1/2 qts/hour is pretty darn good.
Rangers were originally designed to run sloppy using 60wt. mineral oil, thus the .004" to .005" clearance on the main bearings.  Sometimes trying to make this engine operate like a flat engine regarding oil consumption is pure futility.
- "Red" Green
Sent: Sunday, June 22, 2008 9:00:33 PM
Mike,
John
- "Red" Green
To: fairchild club ; fairchildclub@ yahoogroups. com
Hi to all,
John Ellis a/p
Posted: Mon Jun 23, 2008 8:05 am
by John Ellis
'Hi Mike,
The rings and cylinders are not the problem with Ranger oil consumption, it is the quanity of oil to be controlled.
If you can imagine quantity of oil going through bearing with .004 clearance, plus leakage from the crank at 60 pounds pressure. This could easily be 1/2 gallon per minute or more.
Now look at the pistons, they all have a 1/8 inch hole on each side to enable piston pin clip removal. The total of these holes is 1 1/2 inch hole by-passing the oil rings completely.
The engines i have running all use around 1 quart every 2 - 3 hours untill one of those damn plugs start to leak bad.
Give me a call and I can fill in more details..
John
Sent: Monday, June 23, 2008 6:45 AM
- "Red" Green
Mike,
John
- "Red" Green
Hi to all,
John Ellis a/p
Posted: Mon Jun 23, 2008 9:07 am
by John Ellis
'Mike,
Sorry, failed to give my phone # 573 450 1676.
John
Posted: Mon Jun 23, 2008 6:53 pm
by Bob Haas
'I concur with Mike, if you can stay in the air and cover ground
with that kind of oil consumption, that's
Not bad. When you start hopping rides and do wifferdills that when you dip
the stick often. Bob Haas.
_____
On Behalf Of John Ellis
Sent: Monday, June 23, 2008 10:09 AM
Hi Mike,
John
good.
futility.
- "Red" Green
Mike,
John
low.
- "Red" Green
Hi to all,
loose again.
John Ellis a/p
