'Some one out there must have resolved this issue in the past, so before searching the web, allow me to ask.
There is a Fafner Bearing that is used on the rudder (I think it is also used on the ailerons)
The part number appears to be KF4A
The dimensions are? .75" OD, .25" ID, .50" Width
It is a felt sealed ball bearing.
I need about 8.
Any source or replacement options.? If replacement options, do we have the appropriate paperwork?
Richard Smith
Austin, Texas
Re: Bearings for PT-19/23/26
Curt Kinchen
'It would appear, from the link below, that the obsolete part number KF4A would be replaced with a KP4A. The difference being the seal type.
http://www.promshop.info/cataloguespdf/form643.pdf
Here's a source I found with a quick search.
http://www.machinemadness.com/fafnir_bearings.htmCurt Kinchenptcurt@msn.com
To: fairchildclub@yahoogroups.comFrom: pt19flyer@aol.comDate: Wed, 21 May 2008 13:06:45 -0400Subject: [fairchildclub] Bearings for PT-19/23/26
Some one out there must have resolved this issue in the past, so before searching the web, allow me to ask.There is a Fafner Bearing that is used on the rudder (I think it is also used on the ailerons)The part number appears to be KF4AThe dimensions are? .75" OD, .25" ID, .50" WidthIt is a felt sealed ball bearing.I need about 8.Any source or replacement options.? If replacement options, do we have the appropriate paperwork?Thanks,Richard SmithAustin, Texas[Non-text portions of this message have been removed]
Curt Kinchen
'On more careful examination what I said may not be correct. The KP4A may only be .25" thick(according
to the source website info).Curt Kinchenptcurt@msn.com
To: fairchildclub@yahoogroups.comFrom: ptcurt@msn.comDate: Wed, 21 May 2008 11:33:34 -0700Subject: RE: [fairchildclub] Bearings for PT-19/23/26
It would appear, from the link below, that the obsolete part number KF4A would be replaced with a KP4A. The difference being the seal type.http://www.promshop.info/cataloguespdf/form643.pdfHere's a source I found with a quick search. http://www.machinemadness.com/fafnir_bearings.htmCurt Kinchenptcurt@msn.com To: fairchildclub@yahoogroups.comFrom: pt19flyer@aol.comDate: Wed, 21 May 2008 13:06:45 -0400Subject: [fairchildclub] Bearings for PT-19/23/26Some one out there must have resolved this issue in the past, so before searching the web, allow me to ask.There is a Fafner Bearing that is used on the rudder (I think it is also used on the ailerons)The part number appears to be KF4AThe dimensions are? .75" OD, .25" ID, .50" WidthIt is a felt sealed ball bearing.I need about 8.Any source or replacement options.? If replacement options, do we have the appropriate paperwork?Thanks,Richard SmithAustin, Texas[Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
pt19flyer@aol.com
'Curt,
We found some that are the same size OD and ID, but .25 width.?
We could use them if we had a spacer of come sort plus the paperwork to go along with it.
Any ideas?
Richard
Sent: Wed, 21 May 2008 1:39 pm
Any ideas?
Richard
Curt Kinchen
'Here's another one with some in stock....in Australia:)
http://nswbearings.com/
To: fairchildclub@yahoogroups.comFrom: pt19flyer@aol.comDate: Wed, 21 May 2008 15:01:01 -0400Subject: Re: [fairchildclub] Bearings for PT-19/23/26
Curt,We found some that are the same size OD and ID, but .25 width.? We could use them if we had a spacer of come sort plus the paperwork to go along with it.Any ideas?Richard-----Original Message-----From: Curt Kinchen To: fairchildclub@yahoogroups.comSent: Wed, 21 May 2008 1:39 pmSubject: RE: [fairchildclub] Bearings for PT-19/23/26On more careful examination what I said may not be correct. The KP4A may only be .25" thick(accordingto the source website info).Curt Kinchenptcurt@msn.com To: fairchildclub@yahoogroups.comFrom: ptcurt@msn.comDate: Wed, 21 May 2008 11:33:34 -0700Subject: RE: [fairchildclub] Bearings for PT-19/23/26It would appear, from the link below, that the obsolete part number KF4A would be replaced with a KP4A. The difference being the seal type.http://www.promshop.info/cataloguespdf/form643.pdfHere's a source I found with a quick search. http://www.machinemadness.com/fafnir_bearings.htmCurt Kinchenptcurt@msn.com To: fairchildclub@yahoogroups.comFrom: pt19flyer@aol.comDate: Wed, 21 May 2008 13:06:45 -0400Subject: [fairchildclub] Bearings for PT-19/23/26Some one out there must have resolved this issue in the past, so before searching the web, allow me to ask.There is a Fafner Bearing that is used on the rudder (I think it is also used on the ailerons)The part number appears to be KF4AThe dimensions are? .75" OD, .25" ID, .50" WidthIt is a felt sealed ball bearing.I need about 8.Any source or replacement options.? If replacement options, do we have the appropriate paperwork?Thanks,Richard SmithAustin, Texas[Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed][Non-text portions of this message have been removed]
pt19flyer@aol.com
'I just got off the phone with my secret source and he is sending me some bearings.? Thanks for your assistance.
Richard
My Secret Source, as in the past is named Joe and lives in PA.? I bet you know him too.
Sent: Wed, 21 May 2008 3:26 pm
Richard
'Hey! You weren't supposed to tell! Just kidding, it keeps him out of trouble.
Quando omni flunkus moritati
- "Red" Green
----- Original Message ----
Sent: Thursday, May 29, 2008 10:35:15 AM
Richard
To: fairchildclub@ yahoogroups. com
http://nswbearings. com/
Curt Kinchenptcurt@ msn.com
To: fairchildclub@ yahoogroups. comFrom: pt19flyer@aol. comDate: Wed, 21 May 2008 15:01:01 -0400Subject: Re: [fairchildclub] Bearings for PT-19/23/26
Curt,We found some that are the same size OD and ID, but .25 width.? We could use them if we had a spacer of come sort plus the paperwork to go along with it.Any ideas?Richard- ----Original Message----- From: Curt Kinchen To: fairchildclub@ yahoogroups. comSent: Wed, 21 May 2008 1:39 pmSubject: RE: [fairchildclub] Bearings for PT-19/23/26On more careful examination what I said may not be correct. The KP4A may only be .25" thick(accordingto the source website info).Curt Kinchenptcurt@ msn.com To: fairchildclub@ yahoogroups. comFrom: ptcurt@msn.comDate: Wed, 21 May 2008 11:33:34 -0700Subject: RE: [fairchildclub] Bearings for PT-19/23/26It would appear, from the link below, that the obsolete part number KF4A would be replaced with a KP4A. The difference being the seal type.http:// www.promshop. info/cataloguesp df/form643. pdfHere's a source I found with a quick search. http://www.machinem adness.com/ fafnir_bearings. htmCurt Kinchenptcurt@
msn.com To: fairchildclub@ yahoogroups. comFrom: pt19flyer@aol. comDate: Wed, 21 May 2008 13:06:45 -0400Subject: [fairchildclub] Bearings for PT-19/23/26Some one out there must have resolved this issue in the past, so before searching the web, allow me to ask.There is a Fafner Bearing that is used on the rudder (I think it is also used on the ailerons)The part number appears to be KF4AThe dimensions are? .75" OD, .25" ID, .50" WidthIt is a felt seal
ed ball bearing.I need about 8.Any source or replacement options.? If replacement options, do we have the appropriate paperwork?Thanks, Richard SmithAustin, Texas[Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed][Non- text portions of this message have been removed]
- "Red" Green
Richard
Jack Threadgill
'Mike, I have the CD done with the crashed PT-19's from the 1940's. Send me
your address off line so I can mail it to you. I had about 12 to 15
pictures.
Jack
Jack Threadgill
1602 Brook Hollow Dr
Bryan, TX 77802
979-779-7155
threadgl@suddenlink.net
On Behalf Of Michael Denest
Sent: Thursday, May 29, 2008 7:18 PM
trouble.
- "Red" Green
To: fairchildclub@ yahoogroups.com
Richard
know him too.
ptcurt@msn.comDate : Wed, 21 May 2008 11:33:34
felt seal
removed]
pictures.
Jack
Jack Threadgill
Bryan, TX 77802
979-779-7155
trouble.
- "Red" Green
Richard
know him too.
felt seal
removed]
