fairchildclub@yahoogroups.com
> From:
michaelmps@yahoo.com
> Date: Sat, 10 May 2008 16:33:38 -0700
> Subject: RE: [fairchildclub] Re: Bob Dunn timing question
> That is what I did because it sounded logical with out timing marks and you say the same thing. Great! I did it and all checks well. Thanks for all the help! Everyone is great on thes site! I hope I can help someone oneday.
> Bob Haas wrote: This is the proper way to set the mags oh the Ranger Engines,
> works every time! Bob H.
> _____
> From:
> On Behalf Of Michael Denest
> Sent: Wednesday, April 30, 2008 10:21 AM
> Subject: Re: [fairchildclub] Re: Bob Dunn timing question
> I use a buzz box and Time Rite indicator. Before I start mag timing, I
> check the mag points for the proper gap of .012" to .015". Then I find the
> #1 cylinder compression stroke to set the card for TDC. I then back the
> blade off then bump the prop in the direction of rotation and listen for the
> buzz box. When I get the tone, I check the card to see where 25° BTDC is
> and adjust the coupling as necessary. I do each mag individually then do a
> final check on both mags. Takes me about 1 hour to do both mags.
> ATS has the Time Rite available but it's several $$$$. If you do a lot of
> engines, it's a great investment.
> Mike
> Quando omni flunkus moritati
> (If all else fails, play dead)
> - "Red" Green
> ----- Original Message ----
> From: rangerrobertmn
> yahoo.com>
> To: fairchildclub@ yahoogroups.com
> Sent: Wednesday, April 30, 2008 8:48:45 AM
> Subject: [fairchildclub] Re: Bob Dunn timing question
> Tom,
> We do it exactly like you do, but instead of a 'degree wheel', we use
> an electronic 'smart level' taped to the prop. When at TDC, we set
> the level to ZERO, then turn the prop 'til it reads 25. Old eyes can
> read inch high digits, easier than 'tiny' marks on a 'degree wheel'.
> Also, someone should have mentioned the unique 'rubber ring' between
> the mag and the mag-drive is really a 'vernier' adjuster. It adjusts
> in 2/3 degree increments. It seems that you rotate it about 15
> degrees in order for it to mesh with the mag-drive, but all that
> effort resulted in 2/3 degree change. Very frustrating until you
> figure out what is happening, but very precise. I wish all mags were
> like that.
> Bob Waldron
> 1939 Fairchild 24 K
> Sky Harbor airpark
> Webster, MN
> --- In fairchildclub@ yahoogroups. com, "Tom Downey"
> wrote:
>> Manufacture a piston stop that will fit the spark plug hole (I used
>> and old spark plug and a 1/2" rod) Place the piston stop in the
> spark
>> plug hole while the engine is at bottom dead center on #1
> compression
>> stroke. Attach a degree wheel to the prop shaft?prop and set at any
>> position, carefully turn the engine in the direction of rotation,
>> until the piston stop is touching the piston. mark the degree wheel
> at
>> that position. rotate the engine backwards until the piston stop is
>> touching the piston again, mark the degree wheel again. TDC is half
>> way between your 2 marks. on the side of the degree wheel that you
>> have not turned the engine.
>> rotate the degree wheel on the shaft until TDC is indicated by the
>> degree wheel pointer, lock it down and rotate the engine backwards
>> until 25 degrees is indicated. stab the mag at "point opening" for
> #1
>> plug.
>> --- In fairchildclub@ yahoogroups. com, "michaelmps"
>> wrote:
>>> I centered both mag indexs prior to pulling the mags and did not
>> move
>>> the prop . After mag overhaul, I restabbed and it worked well
> for
>> the
>>> right but not Quite correct with the left. I would like to find
> out
>>> how to verify the engine is at 25 degress BTDC and try and stab
> the
>>> left mag again. I do not see any Index marks on the Crank. I
> guess
>>> thats what I am asking. Aside from the index mark on the mags.
> How
>>> can I verify 25 BTDC..
>>> Michael
> __________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile. Try it now.
http://mobile.
> yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
