'Bob,
you are right you need both but, Peterson has for both the Rangier and Warner F24's. But not the PT's but, there are several 337's out to use Peterson's engine STC's on Pt's and PT23's he has the STC for the 220 Cont. if the Fed.'s will let us use them as a basis for your or mine from what we heard at Oshkosh this year that may not be possible any more.
John Berendt----- Original Message -----
fairchildclub@yahoogroups.com
Sent: Saturday, November 10, 2007 7:02 AM
Subject: RE: [fairchildclub] mogas
Hey John great to hear from you, I think you will find that the
STC is for the engine only, and only
In an F 24 type airframe. No any other certified airframe such as a Widgeon
or M 62 has a STC. I have
used 92-93 octane rated mo-gas in various Ranger engines for the last 20
years and I have not had to buy a
spark plug since. As I recall two STC's are required, a power plant and an
airframe. Bob Haas.
On Behalf Of fchld
Sent: Saturday, November 10, 2007 8:15 PM
Subject: Re: [fairchildclub] mogas
Mike, yours being experimental you can run any thing that will work. There
is a STC for the Ranger all models from Peterson Aviation Minden Nebraska
(938) 237-9338. The cost is $1.00 per hp. you do not need one so just put in
the mo-gas and fly. Just make sure it does not have alcohol in it
John Berendt.
Sent: Saturday, November 10, 2007 1:12 PM
Subject: [fairchildclub] mogas
Anyone running a Ranger on mogas? I don't know about any STC's but mine
is on an experimental and I'd like to know if this is a viable option.
Mike Danielle
