aeromatic.com
Posted: Mon Jul 23, 2007 3:41 am
'After I got my new engine up and running,I installed the Aeromatic
prop which I had bought from Kent Tarver.
After 2 flights I had the prop adjusted.Obviously Kent knows how to
pre-adjust the Aeromatic in his shop for any given airplane.
Difference in performance is dramatic in my opinion.Ground roll on
grass is at least 25-30% shorter and the initial climb about 25%
better at gross.
A must for everybody who wants to fly into short and hot fields in
summertime.
Changing the weights because of bigger altitude/temperature
differences takes about 10 minutes,so that is no issue for me,because
it improves my safety!
Regards,
Remko'
better at gross.
summertime.
Regards,
Remko'
