Re: Fuselage Cover
james chybicki
Fuselage Cover
'Hi Guys-
Our Fuselage fabric will be here at the end of the
week!
Please advise any critical or tricky areas we should
keep a look out for!
We decided to use the PolyFiber System.
Any Comments would be appreciated.
Jim Chybicki
UC-61K 43-14964/HB-690
Be a better Heartthrob. Get better relationship answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545433'
week!
Jim Chybicki
Buell Powell
Re: Fuselage Cover
'Hi Jim,
Are you going to use Aerothane or Poly Tone paint.
Buell
Buell
> Hi Guys-
> week!
> Jim Chybicki
> UC-61K 43-14964/HB- 690
> ____________ _________ _________ _________ _________ _________ _
> http://answers. yahoo.com/ dir/?link= list&sid= 396545433
David Stroud
Re: Fuselage Cover
'Giday Jim. congrats on your progress. I used the Polyfiber system on my
current ride and have no regrets. Everything was predictable except that
Polyfiber can't do real good math on using flattner ratios. Maybe not an
issue with you.
There are other and newer covering systems out there and I'd be pleased
to hear any feedback on research/use of them that anyone has out there
especially on the non toxic types.
David Stroud Ottawa, Canada
C-FDWS Christavia
Fairchild 51 under construction
and on the gear...
issue with you.
C-FDWS Christavia
and on the gear...
Sent: Tuesday, July 10, 2007 2:48 PM
Subject: [fairchildclub] Fuselage Cover
Hi Guys-
week!
Jim Chybicki
Checked by AVG Free Edition.
Version: 7.5.476 / Virus Database: 269.10.2/893 - Release Date: 7/9/07 5:22 PM
Steve Link
Re: Fuselage Cover
'I own a 1966 Citabria and it will need covering soon. I plan to use the Stewart Systems EPA compliant finishing system....
http://www.stewartsystems.aero/
They are waterborne coatings that are even compatible with installation over other coatings if need be. One of their other pluses is that you can use the same product over fabric and metal so there is no color shift as in the dopes/enamels. Check it out! Tailwinds, Steve.
Sent: Tuesday, July 10, 2007 8:40 PM
Subject: Re: [fairchildclub] Fuselage Cover
issue with you.
C-FDWS Christavia
and on the gear...
Hi Guys-
week!
Jim Chybicki
james chybicki
Re: Fuselage Cover
'Hi Buell
We haven't made up our mind on that yet. The Poly Rep.
is pushing us toward Aerothane with a flatner agent to
match the WW2 paint scheme, have you ever used
Aerothane?
How is your F24 coming along?
--- Buell Powell wrote:
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onese ... fer=1ONXIC'
Aerothane?
> Hi Jim,
> paint.
> Buell
> > Hi Guys-
> > week!
> should
> > Jim Chybicki
> 396545433
____________________________________________________________________________________> >
David Stroud
Re: Fuselage Cover
'Giday Jim. Double check the ratios on using flatner with Aerothane
Polyfiber products. There are math errors in some Polyfiber books.
I used Aerothane and the regular Polytone on my Christavia. I think
the colour was Federal 208 Olive Drab. The polytone is very easy to
spray. I used a real basic Wagner airless sprayer and if you produced
a run in the paint, you can just wipe it off with a paper towel and respray
immediately and no one could tell anything ran. It was idiot proof for sure.
C-FDWS Christavia
and on the gear...
C-FDWS Christavia
and on the gear...
Sent: Wednesday, July 11, 2007 12:20 PM
Hi Buell
Aerothane?
> Hi Jim,
> paint.
> Buell
> > Hi Guys-
> > week!
> should
> > Jim Chybicki
> 396545433
Version: 7.5.476 / Virus Database: 269.10.2/894 - Release Date: 7/10/07 5:44 PM
Buell Powell
Re: Fuselage Cover
'Hi Jim,
On most of my projects I use Poly Tone on the fabric and
Aerothane for everything else. I did use Aerothane on the fabric wings
on a Cessna 120. and am using it on everything on the Fairchild. I have
used Aerothane fully flattened on a Cub inst panel and it works really
well. The Poly Tone is easy to use but doesn't have a shine. The
Aerothane is a little tricky because if you aren't careful it will
run(sometimes it wont run when you are spraying it but will soon after.
and you need a good paint gun and an HVLP gun doesn't work very well for
it. One thing to remember is to give it plenty of time between coats (I
usually wait 30 minuets and then press my thumb on some over sprayed
object. If it comes off on your thumb you need to wait. Hope this helps.
Buell
Buell
> Hi Buell
> Aerothane?
> Jim
> > Hi Jim,
> > paint.
> > Buell
> > > Hi Guys-
> > > week!
> > should
> > > Jim Chybicki
> > 396545433
> http://mobile. yahoo.com/ mobileweb/ onesearch? refer=1ONXIC
james chybicki
Re: Fuselage Cover
'thanks David!
--- david stroud wrote:
Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545469'
> with Aerothane
> Polyfiber books.
> Christavia. I think
> is very easy to
> and if you produced
> C-FDWS Christavia
> and on the gear...
> From: james chybicki
> Hi Buell
> Rep.
> agent to
> Aerothane?
> Jim
> > Hi Jim,
> > paint.
> > Buell
> > > Hi Guys-
> the
> > > week!
> > should
> > > Jim Chybicki
> relationship
> list&sid=
> > 396545433
__________________________________________________________> > >
http://mobile.yahoo.com/mobileweb/onese ... fer=1ONXIC> Yahoo! oneSearch: Finally, mobile search
> removed]
james chybicki
Re: Fuselage Cover
'Hi Buell
That is great info!
Did you cover the F24 yet?
Was there any tricky areas when applying the poly
fiber we should be careful with?
Sick sense of humor? Visit Yahoo! TV's
Comedy with an Edge to see what's on, when.
http://tv.yahoo.com/collections/222'
That is great info!
>> Hi Jim,
> fabric and
> on the fabric wings
> and it works really
> a shine. The
> careful it will
> some over sprayed
> Buell
> > Hi Buell
> Rep.
> agent to
> > Aerothane?
> > Jim
> > --- Buell Powell > wrote:
> > > Hi Jim,
> > > paint.
> > > Buell
> > > > Hi Guys-
> the
> > > > week!
> > > should
> > > > Jim Chybicki
> relationship
> list&sid=
> > > 396545433
> > 396545433
> refer=1ONXIC
Tom Downey
Re: Fuselage Cover
Stiz/Polytone/polyfiber/airtech..
http://aircraftfinishing.com/'
When you folks start using this system you'll never go back to> Hi Jim,
