--- In
fairchildclub@yahoogroups.com, "m51rs" wrote:
> Bob, the plane was lightly loaded.Only me,(160 lbs) and 1/3 tanks.I
> was climbing pretty steep.70-75 mph.
> Carb is clean inside.
> BTW,during level flight this problem did not occur.
> I can try again with more fuel and more speed to see if this
helps..If
> you think it is worth the try.
> You also speak about a void which you try to never let happen.Could
> you please explain this for me?How and why?
> Thanks,
> Remko
> --- In
fairchildclub@yahoogroups.com, "rangerrobertmn"
> wrote:
> > Remko,
> > In FLIGHT attitude, the Fairchild 24 has about 3 p.s.i. pressure
at
> > the carb. In TAKEOFF attitude, there is less pressure. You
don't
> > mention how steep you are climbing. At anything less than 70
mph,
> > you are getting pretty steep. You also don't mention whether the
> > tanks are full. Half full tanks at steep attitude don't provide
> > much pressure at the carb.
> > That said, I suspect that you have a carb problem, not a fuel
flow
> > problem. The only fuel flow problem that I have, occurs when
some
> > fuel has leaked out past the needle valve, leaving a void in the
> > fuel line. This void generally hits the carb all at once, and I
get
> > a 'heck of a surge', to the point where I try to NEVER let it
happen.
> > Bob Waldron
> > 1939 Fairchild 24 K 200hp
> > Stillwater MN
> > --- In
> > > I checked the fuelflow on both tanks at the carburetor side of
the
> > > fuel line.
> > > Left tank:170 liters or app 37 gallons an hour
> > > right tank 150 liters or app 33 gallons an hour
> > > During take off at full power my engine surges.Less power cures
the
> > > problem.I tried leaning the mixture,flying on both tanks,but to
no
> > avail.
> > > Any ideas out there?
> > > Filters inside the carb and strainer are absolutely clean.
> > > Thanks for any help.
> > > Remko
> > > PS:the other engine in our f24 had a fuelpump installed.Could
this
> > be
> > > a hint?
Get the Yahoo! toolbar and be alerted to new email wherever you're surfing.
