hottest cylinder ranger
Posted: Thu Jun 21, 2007 7:26 am
'Does anybody know which cylinder normally runs hottest?
Remko'
Remko'
A Forum for all interested in vintage Fairchild Aircraft
https://board.fairchild-club.org/
has the additional bump on the inside, left side. This creates a>
> Remko,
> #5 is the hottest. 2nd cyl back. Also make sure your installation
> Jamie Treat
Sent: Thursday, June 21, 2007 2:02 PM
Subject: [fairchildclub] Re: hottest cylinder ranger
Thanks Jamie.
Is there a drawing for this 'bump'somewhere on the cd?
My airbox hasn't got it,so I want to install one.
Regards,
Remko
> Remko,
higher pressure to direct air across the #5 cylinder.
> Jamie Treat
Thanks Jamie.
Regards,
Remko
> Remko,
> Jamie Treat
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started.
http://mobile.yahoo.com/mail
door of the Ranger airbox. If you don't have this, you need to find> Remko,
> The "bumps" are a strip of aluminum that is attached to the access
Denest's may be able to shed some light from the Ranger side, most>
> Mike
> Quando omni flunkus moritati
> (If all else fails, play dead)
> - "Red" Green
> From: Jamie Treat
> Sent: Thursday, June 21, 2007 11:21:26 PM
> Subject: Re: [fairchildclub] Re: hottest cylinder ranger
> Remko,
> I have never seen a drawing, only know about it for experience. The
'--- In fairchildclub@yahoogroups.com, "m51rs" wrote:
> Mike,
> The access door of the airbox is just straight from front till back.
> nothing attached to it.
> Over here in Europe it will be impossible to find another door.If
> this really improves cooling,I will have to make it myself I guess.
> If I could get some dimensions and a drawing,this should be
possible
> I hope.
> Or is there someone out there who has a lead to finding the right
> access door?
> Thanks,
> Remko
> > Remko,
access
find
> a door with the bumps. This is standard on all Ranger
installations
> as a way to force cooling air through the cylinders. Send me a
> picture of what you have.
> > Mike
> > - "Red" Green
> > From: Jamie Treat
> > Remko,
The
> likley from the PT side of the house. I bet it started with the Mil.
> Did you get the two pictures I have sent to your e-mail adress this
> morning? It will answer most of your questions.
> I can measure the details and send them to you.
> Karl
> UC-61K HB-ERO
