F-24 main gear shock question
Posted: Mon Jun 04, 2007 1:44 pm
				'Lads, I could use a bit of guidance on the characteristics of the piston
in the F-24 main gear shock. If someone has one apart now ( I remember
Tom Downey did a while back) could someone please measure the diameter
of the piston and the size of the orifice that the fluid passes through? I'm
thinking that the orifice is just a two way hole where the fluid passes back and
forth at the same rate. Could be a number of holes in a circle, etc. ? Could you
confirm that please? I'm having to make up custom built shocks for my 51 project
and this info would be very helpful. Thanks.
C-FDWS Christavia
and on the gear...
C-FDWS Christavia
and on the gear...
