Page 1 of 3
A/D`s
Posted: Wed May 02, 2007 11:47 am
by jameslbryan@btopenworld.com
'Hi Guys
Just a quick Question about a apparent AD? somthing to do with a wing spar inspection?
Ive got G-RGUS on annual and heard about one?
Can anyone point me to the right page on the FAA site as i havent been able to find anything myself.
Best regards
James
Re: A/D`s
Posted: Wed May 02, 2007 3:14 pm
by Cy Galley
'What model and Year Fairchild>
Sent: Wednesday, May 02, 2007 12:44 PM
Subject: [fairchildclub] A/D`s
Hi Guys
Best regards
James
Re: A/D`s
Posted: Thu May 03, 2007 2:26 am
'O sorry she is a f-24-46 forwarder?
Hi Guys
Best regards
James
Part Needed: Coil Spring for Landing Gear sought
Posted: Fri May 04, 2007 10:57 am
by dcasali
'Hi All,
My 1937 24G has been down since last August, when I ground looped it and
broke the usual collection of parts. Rebuild is nearing completion, but
yesterday I received a call from my rebuilder that upon disassembling
the right landing gear oleo strut, he discovered that the coil spring
inside is broken.
He describes the spring as about 1 3/4" in diameter, and 7 1/4 inch
long. Does anyone have an extra spring, or know a good source (ideally
with a part number) for the spring.
Thanks in advance...
Dan Casali
Dan Casali
MacWizard
Box 1286 Ketchum, ID 83340
208.726.5120
Re: Part Needed: Coil Spring for Landing Gear sought
Posted: Fri May 04, 2007 8:49 pm
by robert Etter
'The only thing that I have see or heard of in the past, if you can't find a new spring, you could try to locate a shop that is capable of manufacturing a spring for you.
I know a friend of mine in Kansas City KA. need a tail wheel strut spring for a Waco. He went to a shop near the down town area in K.C. MO., and had one made. The only thing the fabricator wanted to know, "How many do you want and when?" All they really needed was the size of the material used, the spacing of the wraps, the diameter, and the length. They also had the broken as a pattern.
Check with any of the big time Hot Rodders in your area.
Sent: Friday, May 04, 2007 9:56 AM
Subject: [fairchildclub] Part Needed: Coil Spring for Landing Gear sought
Hi All,
inside is broken.
Dan Casali
Dan Casali
MacWizard
208.726.5120
Posted: Sat May 05, 2007 10:00 am
by David Stroud
'These people might be worth a shot.
http://www.tipcopunch.com/images/Tipco_Die_springs_US.pdf
David Stroud Ottawa, Canada
C-FDWS Christavia
and on the gear...
Sent: Friday, May 04, 2007 10:47 PM
Subject: Re: [fairchildclub] Part Needed: Coil Spring for Landing Gear sought
Hi All,
inside is broken.
Dan Casali
Dan Casali
MacWizard
208.726.5120
Checked by AVG Free Edition.
Version: 7.5.467 / Virus Database: 269.6.2/787 - Release Date: 5/3/07 2:11 PM
Posted: Sun May 06, 2007 11:17 pm
by Robert Albee
'Dan: We are rebuilding a F-24R and might have some extra springs, ley me check and will get back to you, Robert
Sent: 5/5/2007 9:00:24 AM
C-FDWS Christavia
and on the gear...
Hi All,
inside is broken.
Dan Casali
Dan Casali
MacWizard
208.726.5120
Re: A/D`s
Posted: Mon May 07, 2007 6:58 am
by fchld
'James There are no AD's on the spars on a F24 that we know of.
Were did you hear about the AD?
Fairchild club
Hi Guys
Best regards
James
Re: A/D`s
Posted: Mon May 07, 2007 5:26 pm
'Hi John
Turns out it was bar room banter.
sorry if i worried any one?
James
Fairchild club
Hi Guys
Best regards
James
Re: A/D`s
Posted: Tue May 08, 2007 11:58 am
by robert Etter
'The 4 original spars that I have showed only one area that may need a fairly close inspection. That would be the area around the wing attachment fittings, especially the bottom side. I didn't find any dry rot, but I did see stains, which I attributed to the presence of water.
The wing ribs did show a general failure in glue joint through out the wing, but it wasn't to the point of being really scary. Most of the deterioration I saw, was to the rear tips of the ribs in the flap area. Most notably, the trailing edge in the flap area turned upward slightly.
A note: The spars could be either solid pieces of wood, or up to 5 laminations. If the wings are getting in pretty bad shape, the through bushing used through the wing may be corroded. I have seen the bushing in a known UC-61 wing, and the bushings were all anodized and in good shape. A pre-war civilian wing, they were mostly corroded to some degree.(Not anodized)
Sent: Monday, May 07, 2007 3:51 PM
Subject: Re: [fairchildclub] A/D`s
Hi John
James
Fairchild club
Hi Guys
Best regards
James
