Fw: Fwd:rfq engine parts warner
Posted: Mon Feb 19, 2007 6:59 am
'I'm forwarding this request to the group. Marinoni is looking for Warner parts.
Quando omni flunkus moritati
- "Red" Green
----- Forwarded Message ----
To: mjd12k
Sent: Monday, February 19, 2007 5:24:56 AM
Subject: Fwd:rfq engine parts warner
Good morning sir
in our maintenance we have one engine Warner 165HP.
I ask you if is possible a help for to need the parts
for the revision.
Please reply me A.S.A.P. is very urgent
Many thank's for your collaboration
Marinoni Pietro
Officine Aeronautiche David
Via Galileo Galilei Trav. III N°4
25010 San Zene Naviglio
Brescia
Italy
Tel. +39 030-2667133
fax +39 030-2160877
E-mail pietromarinoni@libero.it
We attached the parts list
P/N DESCRIPTION QTY
8222 SLEEVE 1
8289-1 GASKET 2
7253 RING 1
LW-757 LOCK WASHER 8
7161 GASKET 14
7875 PACKING 1
7884 GASKET 1
8027 GASKET 7
7150 GASKET 1
7849-02 VALVE GUIDE 7
7261-00 VALVE GUIDE 7
7612 RETAINER 7
7555 RETAINER 7
G-547 GASKET 7
G-771 GASKET 14
7963 HOSE 2
7272 GASKET 7
7906 PACKING 7
7926-1 GASKET 14
G-555 GASKET 1
8034 HOSE 2
7963 HOSE 2
SE-833 SEAL 1
7931 GASKET 1
8226 GASKET 2
7594 GASKET 1
7930 GASKET 2
G-791 GASKET 2
7925 GASKET 2
7295 GASKET 2
G-545 GASKET 4
G-765 GASKET 1
G-766 GASKET 1
7921 GASKET 1
7104 PACKING 1
7883 GASKET 1
SE-797 SEAL 1
G-767 GASKET 1
7930 GASKET 4
8262 GASKET 1
8067 GASKET 1
SE-832 SEAL 2
8065 RETAINER 1
8195 GASKET 1
8057 RING 2
8056 RING 1
G-825 GASKET 1
7589 PISTON RING 7
75089-1 PISTON RING 7
7537 PISTON RING 7
7538 EXPANDER 7
8088 BEARING UPPER 1
8087 BEARING LOWER 1
7235 BOLT 4
7236 NUT 4
7072-B BOLT 6
AN355-5 NUT 6
7069 BUSHING 7
7922 GASKET 1
7808 GASKET 1
G-571 GASKET 1
7156 GASKET 1
8:00? 8:25? 8:40? Find a flick in no time
with the Yahoo! Search movie showtime shortcut.
http://tools.search.yahoo.com/shortcuts/#news'
- "Red" Green
To: mjd12k
Good morning sir
for the revision.
Marinoni Pietro
Brescia
Italy
fax +39 030-2160877
P/N DESCRIPTION QTY
8222 SLEEVE 1
8289-1 GASKET 2
7253 RING 1
7161 GASKET 14
7875 PACKING 1
7884 GASKET 1
8027 GASKET 7
7150 GASKET 1
7612 RETAINER 7
7555 RETAINER 7
G-547 GASKET 7
G-771 GASKET 14
7963 HOSE 2
7272 GASKET 7
7906 PACKING 7
7926-1 GASKET 14
G-555 GASKET 1
8034 HOSE 2
7963 HOSE 2
SE-833 SEAL 1
7931 GASKET 1
8226 GASKET 2
7594 GASKET 1
7930 GASKET 2
G-791 GASKET 2
7925 GASKET 2
7295 GASKET 2
G-545 GASKET 4
G-765 GASKET 1
G-766 GASKET 1
7921 GASKET 1
7104 PACKING 1
7883 GASKET 1
SE-797 SEAL 1
G-767 GASKET 1
7930 GASKET 4
8262 GASKET 1
8067 GASKET 1
SE-832 SEAL 2
8065 RETAINER 1
8195 GASKET 1
8057 RING 2
8056 RING 1
G-825 GASKET 1
7589 PISTON RING 7
7537 PISTON RING 7
7538 EXPANDER 7
7235 BOLT 4
7236 NUT 4
7072-B BOLT 6
AN355-5 NUT 6
7069 BUSHING 7
7922 GASKET 1
7808 GASKET 1
G-571 GASKET 1
7156 GASKET 1
