How to request aircraft records CD from the FAA
Posted: Thu Nov 30, 2006 4:21 pm
'Three years ago I posted instructions on how to order a copy of a CD
containing all of an aircraft's records held on file with the FAA. I
just tried to do this again, and found that the data is still available,
but the process has changed, and the price (still a bargain) has doubled.
As noted by ranger440c5 recently, this is public
information, and is available for any aircraft in the registry. It
should include all 337's on file for that aircraft.
The cost now is $10 per CD.
To place an order you will need a credit card, and the aircraft N
number and serial number of the aircraft you are requesting data on. You
can find this at:
http://www.faa.gov/licenses_certificates/aircraft_certification/aircraft_registry/n_numbers/
To place an order, go here:
http://www.faa.gov/licenses_certificates/aircraft_certification/aircraft_registry/copies_aircraft_records/
Note that the field for N number wants only the number, not the N or NC
prefix.
The last time I did this, it took a couple of weeks to get the CD. We'll
see how long this order takes.
Dan Casali
MacWizard
Box 1286 Ketchum, ID 83340
208.726.5120
can find this at:
prefix.
Dan Casali
MacWizard
208.726.5120
