F-24 Fuel line routing.
Posted: Sat Oct 21, 2006 11:23 am
'I am in the process of making new fuel lines for my 24, from the fuel shut-off up to the wing root. I sure can see that it would be a real bear, to fabricate them, if all or most of the sheet metal around the nose is still in place. I am quite fortunate in one respect. I don't have any of that in place, but that leaves me a long way from flying again.
I am trying to routing the lines up the front side of the door post, then over the top of the mount that is used for the assist strap. There is barely enough room to do it. I should know by the end of this weekend it is possible. I will also be able to measure the distances between each bend, and the degrees of each bend and the radius of the bend. I am presently thinking, if the tubing has the proper bends in place, the only things that will need to be done would be to uncover the door post and to remove the fuel shut-off valve. It looks like the trickiest part would be to get the fuel lines to make a straight in shot to the shut-off valve.
Again. I should know better, by the end of the weekend.
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net
