Re: Digest Number 1393
Posted: Wed Oct 11, 2006 10:25 am
by Buhwana
'Thanks for all the help everyone. I took a measurement today when the
engine was cold but it was still about 3/64" or .046875. Still seems
too much and will have a look at the items mentioned on the board.
> THERE ARE ALSO SPACERS AT THE THRUST BEARING WHICH MAY
> NEED ATTENTION, OR THE THRUST BEARING ITSELF MAY BE
> WORN. ALSO, CHECK TO SEE IF THE CRANK ITSELF IS
> MOVING. MAY BE THE PROP THRUST NUT NEEDS TIGHTNING. I
> BELIEVE IT TAKES ABOUT 600 LBS TORQUE.
> BOB DUNN
