Re: props, brakes, tailwheel -- best setup for an upgrade on ...
Posted: Fri Oct 06, 2006 12:28 pm
'Hi Dan,
Glad you were well insured and also not hurt.
I have a 1937 Fairchild 24-G. It has a aero-matic prop. It gets off quick
and has a great climb. It cruses at 110 to 115 mph at 1850 rpm. I like it.
I have a tail wheel lock operated from the cockpit. The thing I like most
about it is it stops the shimmy. (Just have to remember to unlock it before
trying to turn.) This is something I designed years ago and installed and had
signed off. No original part of the airplane is changed so it can be removed
and go back to original. If you would like a copy of the design let me know and
I will mail it to you.
I think the mechanical brakes are great. I can do a full throttle run up
and the plane don't move. I had the drums turned and new pads put on about
1979 during the rebuild and they have always operated smooth.
Let me know if I can of further help.
George Olson'
George Olson'
