props, brakes, tailwheel -- best setup for an upgrade on a Warner 1
Posted: Mon Oct 02, 2006 1:27 pm
				'Hi All,
This is embarrassing. I broke my 1937 Fairchild 24G; I ground looped on
landing a month ago and collapsed the right gear.
When the plane dropped, it took about 3" off the wood prop.
Happily, I am well insured. The aircraft wasn't too badly damaged and
will be rebuilt this winter. I want to improve the ground handling by
making some changes during the rebuild (cause I'm just not good enough)
and I have some decisions I need to make before the rebuild starts. I
need to tap the collective wisdom of the group here. My three main
concerns are:
1) Prop replacement
My 24G has a Warner 145 engine, and had a wood Sensinich 86CA-63
mounted on it. A table from Sensinich shows the standard prop as an
86CA-67 (this is called out on the Type Certificate) and a cruise
prop, 86CA-69. No climb prop is given.
The 86CA-63 is given as the standard prop for a 24-C8C, also Warner
145 powered.
Now I can't really say my 24G has ever excelled in climb at my home
field elevation (3725 msl), nor has it ever come close to the book
cruise speed, which I now understand -- before I'd thought the
published value was marketing fluff. My question is, if I go to the
-67, just how badly will my already non-spectacular climb
performance deteriorate? Anyone ever had the opportunity to compare
these props on a Warner 145?
2) Tailwheel
My 24G has its original, free pivoting (non-steerable) tailwheel. I
attribute much of the excitement during landing rollouts to this
fact, but had left it unchanged because it was "authentic". Going
thru the logbooks, I found it had its first authentic ground loop
rebuild in 1939. During this repair I want to install some form of
tailwheel steering.
I know many Fairchilds suffer from tailwheel shimmy (mine certainly
did) and I've been told it can be cured-- but it looks like a tough
process. I once saw a 24 with a Cessna 185 tailspring and Scott
tailwheel installed. I know its ug ug ugly, but it sure looked
businesslike and foolproof. Anyone have experience with that setup?
Or a better idea? I am open to any suggestions.
3) Brakes
My 24G has mechanical, cable actuated drum brakes. I find (and the
owner before me found the same) that it is almost impossible to stop
the aircraft in a straight link on rollout using the brakes -- at
least on pavement. I don't even think about short field landings. My
question is, is this a flaw in my setup (out of round drums,
perhaps) or just the way they work. I don't think I want to go to
Hayes brakes, given the amount of verbiage on this board devoted to
keeping them working. Should I just bite the bullet and go to
Clevelands?
Any thoughts on the above greatly appreciated. Thanks
Dan Casali
MacWizard
Box 1286 Ketchum, ID 83340
208.726.5120
concerns are:
1) Prop replacement
145 powered.
2) Tailwheel
tailwheel steering.
3) Brakes
Clevelands?
Dan Casali
MacWizard
208.726.5120
