'The 706 Type Certificate for a R46 (Temco) calls for a 28 degree up
measurement for the elevator, and I have two other manuals calling
for a minimum of 35 degrees up on UC-61K models. Which way to go
here? Is the Type Certificate the final word? I guess they could make
a typo like anybody else.
Also there's a discrepancy on down elevator. The TCDS calls for 20
degrees down, the Fairchild F-24R46 handbook calls for 25 degrees
down. What's a good way to go here!
Hanford,Ca'
Re: Elevator measurements
'TCSD above all others. It is approved data while the
manufacturers information is acceptable.
--- Tom Mueller wrote:
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com'
__________________________________________________> The 706 Type Certificate for a R46 (Temco) calls for
> a 28 degree up
> manuals calling
> Which way to go
> TCDS calls for 20
> for 25 degrees
> Tom
> Hanford,Ca
Do You Yahoo!?
'I meant TCDS. Use ATC 706 for your control throws as
it is approved data while the manufacturers manuals
are acceptable.
--- Michael Denest wrote:
Do You Yahoo!?
are acceptable.
__________________________________________________> TCSD above all others. It is approved data while
> the
> for
> > a 28 degree up
> other
> > manuals calling
> > Which way to go
> > TCDS calls for 20
> > for 25 degrees
> > Tom
> > Hanford,Ca
> Do You Yahoo!?
> protection around
Do You Yahoo!?
