'I have a '39 F24. How much play should be in the tailwheel connecting
link where it attaches to the fuselage? I seem to have excessive side
to side wobble as if the bolt holes are elongated at the fusealge
attach point. Thanks in advance for any input. - gary'
Re: Tailwheel Connecting Link
'Gary,
You should near zero. The tangs that are welded on the square tubing were
never designed to last this long.
This is what I do. I take steal bushing stock and weld in place on the
outside of each tang. Then I cut out the center section. I then install
bronze bushing stock. When bushing wears, I press out and install new
bushings and bolt. Back to near zero clearance.
Jamie
Aircraft Restoration & Repair
Kelly Airpark
http://www.kellyairpark.com
HM/Shop 303-648-0130
JamieTreat@direcway.com
Jamie
Kelly Airpark
Sent: Tuesday, February 21, 2006 11:19 AM
Subject: [fairchildclub] Tailwheel Connecting Link
'Jamie - As I suspected and a similar fix to what I envisioned. I just bought this airplane from Kevin House (great guy, by the way). He had a tailwheel shimmy and sent it to Charlie Bell for rebuild before my purchase. I suspect this may have been the problem all along. Now, will this require some fabric work that may keep me from Sun-n-Fun...
Thanks for the help. - gary
"Jamie S. Treat" wrote: Gary,
Jamie
Kelly Airpark
Jamie
Kelly Airpark
SPONSORED LINKS
Private plane Fairchild semiconductor Plane reservation Fairchild Jet plane Pedal plane
YAHOO! GROUPS LINKS
Visit your group "fairchildclub" on the web.
Brings words and photos together (easily) with
PhotoMail - it's free and works with Yahoo! Mail.
'Gary,
Met Kevin and his wife last year at Sun-n-fun. I flew Bob Haas's 24R46 to
the event. Met Al before he passed away. I purchased a landing gear for a
24W40 model than I'm rebuilding.
If you Tig Weld you can do it without any fabric work at all.
Jamie
Jamie
Sent: Wednesday, February 22, 2006 6:53 AM
Subject: Re: [fairchildclub] Tailwheel Connecting Link
> Jamie
> Kelly Airpark
> Elbert, CO 80106
> From: "daltonagary"
> To:
> > Yahoo! Groups Links
> SPONSORED LINKS
> Private plane
> reservation
> Fairchild Jet plane
> Pedal plane
> YAHOO! GROUPS LINKS
'Jamie - Thanks for the help. I'll let you know how it turns out.
Are you planning to go to Sun-n-Fun this year also? If so, I'd like
to meet you. Last year I camped under the wing of my Starduster Too.
I plan to sleep under my Fairchild wing this year. - gary
--- In fairchildclub@yahoogroups.com, "Jamie S. Treat"
24R46 to>
> Gary,
for a> the event. Met Al before he passed away. I purchased a landing gear
just> 24W40 model than I'm rebuilding.
> Jamie
> From: "Gary Dalton"
> To:
He had a> > bought this airplane from Kevin House (great guy, by the way).
Now, will> > tailwheel shimmy and sent it to Charlie Bell for rebuild before my
tubing were> > this require some fabric work that may keep me from Sun-n-Fun...
on the> > never designed to last this long.
install> > outside of each tang. Then I cut out the center section. I then
connecting> > bronze bushing stock. When bushing wears, I press out and install new
> > Jamie
> > Kelly Airpark
> > Elbert, CO 80106
> > JamieTreat@...
> > From: "daltonagary"
> > To:
excessive side> > > link where it attaches to the fuselage? I seem to have
Plane> > > to side wobble as if the bolt holes are elongated at the fusealge
> > > Yahoo! Groups Links
> > SPONSORED LINKS
> > Private plane
Service.> > reservation
> > Fairchild Jet plane
> > Pedal plane
> > YAHOO! GROUPS LINKS
> > Yahoo! Groups Links
'Gary,
I plan on going to Fla. If my Dad is up to it, will head that way. I may end
up flying a Pt-19 to the event.
Jamie
Jamie
Sent: Friday, February 24, 2006 6:32 AM
Subject: [fairchildclub] Re: Tailwheel Connecting Link
> wrote:
>> Gary,
> 24R46 to
> for a
>> Jamie
>> From: "Gary Dalton"
>> To:
> just
> He had a
> Now, will
> tubing were
> on the
> install
>> > Jamie
>> > Kelly Airpark
>> > Elbert, CO 80106
>> > JamieTreat@...
>> > From: "daltonagary"
>> > To:
> connecting
> excessive side
>> > > Yahoo! Groups Links
>> > SPONSORED LINKS
>> > Private plane
> Plane
>> > reservation
>> > Fairchild Jet plane
>> > Pedal plane
>> > YAHOO! GROUPS LINKS
> Service.
>> > Yahoo! Groups Links
