'Goran,
I have no hands-on experience of either model, but as an amateur
enthusiast/historian of the Fairchild Argus (and Cornell) the same
question troubled me a couple of years ago. I used the manuals on
Jamie's Fairchild CD and the few contemporary photographs I had to
compile the comparison pasted below.
The manuals were of wartime origin and this is now sixty-plus years
later. No doubt some surviving examples of both models will have
been updated during their military service and very long civilian
careers - hence there may have been many changes made to the
electrical system and the radio fit since these manuals were
written. My document was compiled for the purpose of identifying
service photographs, but it may be useful to your discussion.
According to my sources #42-32117 was an UC-61 serial and
FK313, an RAF Argus Mk.I serial no.
Hope this helps, Tony Broadhurst
Differences between UC-61/Argus I and UC-61A/Argus II as given
in "Pilot's Flight Operating Instructions for Army Models UC-61 and
UC-61A, Navy Model GK-1, British Models Argus I and II Airplanes" --
T.O.NO. 01-115CA-1.
____________________________________________________________________
24W-41A UC-61 Argus I
Engine: Warner R500-7 165hp @2100 rpm/sea level.
"Rudders --- equipped with ground-adjustable trimmer expansion rib
for lateral trimming".
Electrical system:
12 volt battery charged by a WD-120 Champion wind-driven generator
equipped with a brake. The brake control is mounted at the bottom
of the inst. panel. Fuse box on cabin side of firewall.
Glove box on rh. side of inst. panel.
Empty weight: 1630 lbs.
Max gross weight: 2700 lbs.
_____________________________________________________________________
24W-41A UC-61A Argus II
"-- equipped with ground-adjustable trim tabs on ailerons and
rudder".
Control lock on stick and rudder pedals.
Electrical system:
24 volt (nominal) engine driven generator and a 24 volt battery.
Circuit breaker box lower rh. side of inst. panel.
Nav lights:
Switches at top centre of instrument panel.
Radio: Bendix Type 3801-24 radio system, mounted on rh.side of
inst. panel (presumably in the same location as the glove
compartment of the UC-61).
Empty weight: 1740 lbs.
Max gross weight: 2810 lbs.
Conclusions:
Look for the wind-driven generator above the rh. wing strut
arrangement, just inboard of the bracing strut that runs from the
top of the oleo leg to the wing root (UC-61) and the aerial pylons
on top of the wing - near the leading edge, the cabin and rudder (UC-
61A).
--- In
fairchildclub@yahoogroups.com, "swedish_argus"
> Hi
> Jim and I have already started this topic on in a different
discution
> but to give all a better chance to see what's the fuzz is all
about
> I start a new thread.
> I have a F24w-41a with RAF no FK313 AFF 42-32117 and on the RAF
> record file stats it's an Argus I but it has a 165 Hp Warner R 500-
7.
> It all started when I looked into the brake sysyem and found out
> that it had differnt brakecylinders than the standard UC61a , and
it
> has a dashboard with a map/glove compartment on the right side of
> the board like a lot of F24G's has.
> futhermore the woodenstrukture behind the rear windows has the
> strukture of the F24G.
> So i'm a little bit confused.
> So please help me out.
> cheers
> Göran
