Re: New file uploaded to fairchildclub
Posted: Mon Jan 02, 2006 3:44 pm
by Jamie S. Treat
'All,
I have uploaded the updated Fairchild Parts and Services file to the "File"
Section.
Aircraft Restoration & Repair
Kelly Airpark
Elbert, CO 80106
HM/Shop 303-648-0130
JamieTreat@direcway.com
Sent: Monday, January 02, 2006 2:10 PM
Subject: [fairchildclub] New file uploaded to fairchildclub
> Hello,
> This email message is a notification to let you know that
> a file has been uploaded to the Files area of the fairchildclub
> group.
> File : /Parts and Services 2 Jan 06.pdf
> Uploaded by : jstreat360
> Description : FAIRCHILD PARTS AND SERVICE DIRECTORY This document
> provides a listing of shops that have parts or services to support
> Fairchild/Ranger/Warner type aircraft. Updated 2 Jan 2006
> You can access this file at the URL:
> http://groups.yahoo.com/group/fairchildclub/files/Parts%20and%20Services%202%20Jan%2006.pdf
> To learn more about file sharing for your group, please visit:
> http://help.yahoo.com/help/us/groups/files
> Regards,
> jstreat360
Posted: Mon Feb 15, 2016 7:43 am
by sotcafok1
'Yes, it is a common malady.  Check with Mike Kelly or Joe Denest or possibly Steve Dennis, they can give you the details for a fix.  But you may need to check all of your bushings that support the drag link for correct fit  first, then, at the top of the trunnion, check that fitting as well.  Also look at the trunnion collar, the large brass fitting that supports the top of the tail wheel assembly for looseness.  You may need to have some parts machined in order to tighten up things.  Another area to look at is the rudder to tail wheel steering torgue tube.  Its possible that could have either contributed to the problem or has actually been damaged by the violent shaking.  There are instance of breaking the welds in the back end of the fuselage if allowed to go not repaired, not to mention shredding good tail wheels.Hope this helps some.Jim Dagg'
Posted: Mon Feb 15, 2016 7:55 am
by slinky52ya
'Has anyone tried to open this file? All I can do is save it and it is only 1kb. Have not tried to save yet.'
Posted: Mon Feb 15, 2016 5:47 pm
by ccmueller001
'I opened it. It is a request for help on a tail wheel shimmy problem. THere was no other information in the file. Doesn't seem like the right place for a question for help.'
